knock sensor wire
Old May 18, 2007 | 08:46 PM
Purplemaroz28's Avatar
knock sensor wire
I broke the knock sensor wire on my car when changing plugs (was up in there tring to take out the plug and rested a little to much weight on the wire, just adding to an arleady irritable day). So do i have to worry about what gauge wire to cross with or can i just solder across
Old May 18, 2007 | 09:22 PM
If you have enough slack, just solder and heat shrink it back together. If you need to splice in some slack, the same or bigger wire will do.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
4586
Mar 18, 2015 06:31 PM
squarehead
Jan 15, 2015 07:02 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
