knock sensor unpluged bad thing??
Old Feb 7, 2009 | 04:20 PM
c5formula's Avatar
so ive been having some problems with some false knock an thought about just unplugging the sensor. is there a problem with doin this? i unpluged it an took the car out an it seems that im still having some knock retard show up through my scan master. whats wrong?
Old Feb 7, 2009 | 05:03 PM
Unplugging it will give you even more retard. The computer with throw a trouble code and automatically retard spark by maybe as much as 10°. Unplugging sensors is a bad way to troubleshoot a computer controlled car.
It's not uncommon to see a little retard, even if there is no knock count escalating.
Old Feb 7, 2009 | 05:37 PM
c5formula's Avatar
ok well im gonna plug it back in then, just wierd though. the knock retard doesnt start low an climb with the rpm it starts at like lets say 5 degrees then i shoots to 12 then back down to 8 then to 11 an continues to bounce like that under wot???
Old Feb 8, 2009 | 05:06 AM
MikeGyver's Avatar
I don't see how unplugging the knock sensor will help you figure anything out...
That much KR can destroy a motor.
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
