knock sensor size?
Old May 8, 2006 | 01:04 AM
93camaroLT1's Avatar
knock sensor size?
Anybody know what size bolt the knock sensor is? The bolt is huge and the biggest thing I got in a deep socket in metric is a 18mm, so im just trying to figure out what size socket to buy cuz I know i'm probably never gonna need a socket this large for anything else..
Old May 8, 2006 | 01:50 AM
sssalah's Avatar
Re: knock sensor size?
Allways used 21mm deep socket with those, I got a new one though that was 22mm so maybe they just recently changed. This size would come in handy for suspension work too.
Old May 8, 2006 | 02:05 AM
cool, thanks for the reply
Old Jun 10, 2006 | 01:50 PM
plan Z's Avatar
i used a 7/8" socket on mine, but the inside part of the sensor started spinning. apparently in this case you need to find a way to get some vice grips around the outside part of the sensor and wrench it off (im in the middle of doing it right now -PITA!)
Old Jun 10, 2006 | 04:32 PM
yeah, 7/8" would be way too big, even if it was a 22mm sensor, 7/8" would come out to 22.225mm which would for sure slip.
Old Jun 10, 2006 | 07:32 PM
plan Z's Avatar
7/8 fit perfect, but the inner part started spinning (it wasn't slipping, just spinning the inside of the sensor). I had to pull the starter just to get a pair of visegrips in there and turn the sensor.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
