Knock Sensor Removal ?
Old Mar 26, 2008 | 03:13 PM
95zsean's Avatar
Ok I just tried to remove the knock sensor and i put a 7/8 socket on it and just the inside turned NOT the whole thing How do you get this out?
Old Mar 26, 2008 | 03:20 PM
MEAN LT1's Avatar
Unless it was put on too tight which often it is, the whole thing should rotate.
Old Mar 26, 2008 | 03:22 PM
95zsean's Avatar
Any thoughts on how to get it out? Please
Old Mar 26, 2008 | 03:30 PM
SS RRR's Avatar
bigass channel locks. i don't think i'd reuse that one.
Old Mar 26, 2008 | 04:07 PM
95zsean's Avatar
Found a trick from "sweatred95ta" Thanks for posting your FIX!!!
Old Mar 26, 2008 | 05:00 PM
caldercay's Avatar
If you post a thread asking how to do something, and you find the
answer elsewhere, always post back the fix for others to benefit.
Old Mar 26, 2008 | 06:40 PM
dangalla's Avatar
vise grips with a extension and a socket to use as leverage attached to the vise grips handle
i had a hard time with mine... and i had the motor out
Old Mar 26, 2008 | 09:31 PM
95zsean's Avatar
I bumped the thread with the answer.
Old Mar 26, 2008 | 10:04 PM
caldercay's Avatar
I must have missed the response. The only response I see is:
"Found a trick from "sweatred95ta" Thanks for posting your FIX!!!"
Not really an answer. I don't see a reply from "sweatred95ta".
Did they reply in another forum?
Old Mar 26, 2008 | 10:08 PM
dangalla's Avatar
i can see your getting really upset about this and i can only imagine how hard it would be for you to look down two threads, or look at the answer i replied to your post, so here is a link to the thread
https://www.camaroz28.com/forums/sho...d.php?t=462872
Old Mar 27, 2008 | 02:16 PM
95zsean's Avatar
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
