Knock Sensor problems
Old Jun 7, 2003 | 05:02 PM
m0nk's Avatar
Im running a code 43? i think thats the number, but its definatly the knock sensor code if thats the wrong #. Ive heard from some people its definatly the sensor, and my parents mechanic says its the wiring. But I need to try and find out myself because I need to pay for my car instead of paying to fix it So I was wondering from past experiences if any of you guys have run into this problem, and was it the sensor or the wiring? I do have a datamaster record of one of my recent runs if that helps any.
Old Jun 7, 2003 | 08:40 PM
There is a single wire attached to the KS. Pull it off with the key "on" and check the voltage from the single wire to the block (ground). Should be 5V +/-1V. If you've got the volts, your wiring is OK.
Old Jun 7, 2003 | 10:54 PM
If the wiring is good, with Key OFF, connector off. measure the resistance between the KS terminal and ground. Resistance should be between 93K to 107K ohms for your OBD-II sensor. If it is not, the sensor is faulty or the sensor is not making good contact with the block.
If all that is good, it might be the knock module or faulty pcm.
Old Jun 8, 2003 | 10:47 PM
m0nk's Avatar
I have an obd1 ks because the computer was changed to obd1, is the resistance the same?
Old Jun 8, 2003 | 10:50 PM
Sorry, I did not catch that. The OBD-I KS is 3300-4500 ohms.
HectorM52
Jul 30, 2017 11:46 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
