Knock Sensor Plugged?
Old Jul 12, 2007 | 02:50 PM
LenT1's Avatar
I just noticed on my new engine that the knock sensor on the passenger side is not there and it is replaced with some kind of metal plug.
Well my first quesiton is, is the knock sensor a must have for an LT1? Should I just unscrew this thing and replace it with a knock sensor?
Input and advise please!!
Old Jul 12, 2007 | 03:46 PM
multicar's Avatar
Yes, remove the plug and screw in the knock sensor. The hole also doubles as the block coolant drain, so use some sort of removable sealant on the threads.
Old Jul 12, 2007 | 03:50 PM
Buttercup's Avatar
Be careful about using sealant on the knock sensor, use it sparingly. Also pay close attention to the torque applied to it.
Old Jul 12, 2007 | 04:41 PM
seawolf06's Avatar
If your car's pcm has had the knock sensor deleted, then putting a sensor in the hole won't do anything. You should also check to make sure they didn't just cut the connector off as well.
If they didn't delete it and the connector is still there, you need to put one in asap. The computer is pulling a lot of timing out.
Old Jul 12, 2007 | 04:44 PM
LenT1's Avatar
The car is just a roller right now. No engine installed. Is it bad to tune out a knock sensor? I was wondering if I could just leave it out and have the pcm tuned or is it good to have a knock sensor?
Old Jul 12, 2007 | 04:49 PM
seawolf06's Avatar
I have mine tuned out, but it's a fresh motor. Some people wouldn't drive their car without one, but I've found it to be unreliable with a modded car.
Old Jul 12, 2007 | 04:54 PM
Sweetred95ta's Avatar
I have mine turned off as well. If the car is fairly stock, I recommend you re-install it.
Old Jul 12, 2007 | 05:53 PM
If you don't have it tuned out, with no sensor, you're going to get constant knock retard, which will hurt performance.
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
