knock sensor and obd1 conversion???
Old Jan 22, 2005 | 08:36 PM
red96z's Avatar
i read somewhere that doing an obd1 conversion requires swapping the knock sensor.i was under the impression that all i had to do is change the senor out from my obd2 cpu to my new obd1 cpu.im doing the pacesetter lts with no egr and air also so other than the tuning is there anything else i should know when doing the swap.also i have the cc306 and bryan from pcmforless says the obd1 cpu and swapping the slps to lts will give a nice gain??
Old Jan 22, 2005 | 08:59 PM
madwolf's Avatar
Re: knock sensor and obd1 conversion???
If you are buying his conversion kit, you don't need to do anything. If you do have an LT4 knock module in your OBD2, you can swap it over to the conversion kit you will get. If you are doing the conversion on your own (your own OBD1 PCM, not a modified one) then yes, you will also need to change your knock sensor.
Old Jan 22, 2005 | 09:00 PM
96capricemgr's Avatar
http://hometown.aol.com/protools4/odb2.htm This was put together by one of the b-body guys it shows what you need too do to the OBD1 pcm too make it work with your current knock sensors.
Old Jan 22, 2005 | 09:01 PM
madwolf's Avatar
That will only work on 2 knock sensor cars.
EDIT: the text instructions will work for an F-body, but you don't have to change the oxygen sensors.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
4586
Mar 18, 2015 06:31 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
