Throttle Body
Old Jan 22, 2005 | 02:06 PM
cbmcharge's Avatar
Throttle Body
I have a LT1 with CAI, descreened MAF, 1LE Elbow, MAC Headers, no CAT, Hooker cat-back, PCM for Less custom tuning.
Do I have enough mods to benefit from a larger throttle body?
If not, would the future install of a HotCam give me enough mods to benefit from a larger throttle body?
Or does the stock TB flow plenty of air?
Old Jan 22, 2005 | 02:13 PM
IllusionalTA's Avatar
Re: Throttle Body
i've made over 300rwhp through a stocker.. I'm sure a lil bigger will help such as a 52mm a lil bit.. W a cam the diff. will be more apparant.. and can't hurt.. to big and it'll seem like a slug.. i tried a 58mm on mine and didn't like it at all..
Old Jan 22, 2005 | 02:15 PM
eagleknight97's Avatar
Re: Throttle Body
Stock TB flows enough till your upwards of 400hp. If you have extra money and are dead set on gettin one, its not gonna hurt ya, but it wont really help you out. Plus, you need to open up the intake openings on the Intake to use a 58mm TB, the stock opening are only 52mm.
Old Jan 22, 2005 | 02:38 PM
cbmcharge's Avatar
Re: Throttle Body
If I do purchase one, I would probably buy the 58 to allow for future growth. Is there a problem buying too big? I figured it would work fine I would just not be using it to its full potential. Is this correct?
Old Jan 22, 2005 | 05:40 PM
cbmcharge's Avatar
Re: Throttle Body
And I am aware that the intake openings are only 52mm
Old Jan 22, 2005 | 09:06 PM
my94blackz's Avatar
Re: Throttle Body
I went to the dyno and my bbk 52 made no more than the stocker, i made 365na rwhp. So hope that helps.
Old Jan 22, 2005 | 09:36 PM
96capricemgr's Avatar
Re: Throttle Body
I agree with the already posted info, but to test this for yourself check WOT vacuum if there is more than about 1.5" then you have a restriction at or before the TB it is up too you to figure out exactly what the restriction is though.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
