Knock sensor install torque spec...
Old Jul 31, 2007 | 08:01 PM
wrd1972's Avatar
Still chasing KR.
Someone suggested that running the KS as loose as possible will help reduce KR. Also I am confused as to whether teflon tape helps or hurts.
Does anyone know the torque spec for installing the knock sensor and have a comment on the teflon tape?
I know mine is rather tight.
Old Jul 31, 2007 | 08:09 PM
15 lb. ft. for the knock sensor. I don't see the harm in a couple of wraps of teflon tape to help it seal.
Old Jul 31, 2007 | 08:50 PM
wrd1972's Avatar
Wow I know I have over torqued the sensor now, I will loosen it up some tomorrow. Damn I hope that helps with the KR problem.
Thanks Shoe.
Old Jul 31, 2007 | 09:03 PM
JP95ZM6's Avatar
I ldid, too. Tightened it like a pipe plug the first time. A while ago I loosened & hand-retorqued mine as part of my KS chasing, but no help.
Part of testing the KS is confirming the sensor body has good electrical contact with the block. I think teflon tape could mess that up if there is enough to add some cushion between the threads. I do NOT know if the sensor will still make good electrical contact with teflon tape, I'm just raising a potential issue. Has anybody checked for this?
Old Jul 31, 2007 | 09:30 PM
wrd1972's Avatar
Update:
I just could not wait till tomorrow so off to the garage I went.
My KS was big time loose, enough to turn without a tool. I am positive that when I installed it I torqued it well so somehow it loosened up in just a few days. I torqued it to 15# so I will no tomorrow if it helped.
The comment regarding the Teflon tape causing the sensor to not ground is very plausible. I wonder if the damn thing can actually be too loose and exposed to resonance and vibes?
Old Jul 31, 2007 | 10:17 PM
The metal of the threads are going to cut through some of the tape (if you don't overdo it), so I would think it would make contact ok. All you have to do is use a meter to see if it is grounding ok. The other thought is whether the tape creates a "cushion" that dampens the transmission of actual knock.
Old Jul 31, 2007 | 10:23 PM
mdacton's Avatar
tape will not make a difference.
wrd I think you have another problem
Old Aug 1, 2007 | 08:18 AM
wrd1972's Avatar
Update:
After finding that the KS was very loose, I torqued it down to 15#. I now have nearly 0 KR all the time in NON-WOT conditions. There was an occasional spike from 2-3 KR but it quickly recovered.
I have not hammered on it yet but I soon shall. My guess is I will still get that spike to 5 during off gas shifts same as before. Maybe it will be gone.
If I still have KR and can play with the newer LT4 KM and the tunes a bit more.
Old Aug 1, 2007 | 09:33 AM
Javier97Z28's Avatar
Moderator
Not sure where I read before not to use teflon tape.. I just use teflon sealant paste.
Old Aug 1, 2007 | 10:00 AM
wrd1972's Avatar
I have read about the tape being good and bad, wo Knows for sure.
I was correct regarding WOT, I am spiking to 4-5 KR just like before but it is still fast. Slowly making some progress though.
Old Aug 1, 2007 | 10:19 AM
speed_demon24's Avatar
Just find a good tuner, I was chasing my KR down for months and when I got tuned I never get it anymore. And I'm using teflon tape on the KS.
Old Aug 1, 2007 | 11:33 AM
wrd1972's Avatar
Thats in the works, I would do it right this second if i could. However there is not one anywhere near where I live that knows the LT1. Might be another month or two before it happens. I can go to louisville but they want $400 which sounds pricey to me. maybe that is fair,I have never been dyno tuned before.
I can rent the local Super Flow dyno for $125.00 an hour, again its just getting the tuner to come from Eastern KY thats the problem.
I also figure that since the current tune is getting closer with the help of you guys, the dyno tune should be quick and pain free.
Old Aug 1, 2007 | 12:05 PM
Z28SORR's Avatar
I agree that the teflon tape "should" not be a problem. But as it is commonly used as an insulator for electric wires and your having problems, I would definitely do a continuity check between the sensor and the block. And check the block to chasis ground while your at it, just to eleminate them as a possibility.
HectorM52
Jul 30, 2017 11:46 AM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
