Idle Surge after Stall
Old Jul 25, 2007 | 04:12 PM
White96Z28's Avatar
This issue was visited once on here a couple of years ago, but I haven't seen anything on it since then and it wasn't really ever answered... I've got a 3200 Vig in a fairly stock car. Mods are K&N FIPK, Cutout, and a Catback. In closed loop, the idle surges a couple hundred RPM for a few cycles, then smooths out for a few seconds and repeats the process. It's actually dropped down low enough to stall the car two or three times sitting at a stoplight. I've gone through the usual culprits and I don't seem to have any vacuum leaks, my Maf has been cleaned, and I haven't gotten any strange readings from the MAP sensor... It's done this ever since the stall went in, but it seems a little more noticeable lately. Do I just need a tune, or is there a fix for this?
Old Jul 26, 2007 | 10:07 AM
White96Z28's Avatar
Nobody has any ideas huh? I'm thinking I'll just have it tuned and see if it smooths out...
Old Jul 26, 2007 | 10:12 AM
06lingenfelter's Avatar
well i would definitaly get a tune and then do a fuel system cleaning. is your battery good? my friends car did that and he put just a damn bettery in it and it work fine lol weird huh.
Old Jul 26, 2007 | 10:14 AM
Sweetred95ta's Avatar
How is you IAC responding when it's fluxuating rpm?
Old Aug 1, 2007 | 11:02 AM
White96Z28's Avatar
My scanner was stolen out of the car, so I haven't a clue... I need to get a laptop in it and do some logging. I did actually have some battery problems recently, but I'm getting good voltage, so I can't see that being the problem. Anyway, I just ordered a set of LT's, so I'm going to install them and change out the O2's and then I can tune it because I won't be touching the motor for a little while after that.
Old Aug 1, 2007 | 01:32 PM
I'm not really sure how much a tune will be able to help this issue.
Old Aug 1, 2007 | 01:50 PM
White96Z28's Avatar
I'm not really either, but I've cleaned out the IAC and the MAF, and it didn't have any effect on it at all. I'm sure I can play with it in the tune and at least get it more stable than it has been.
Noenav
Mar 1, 2019 07:38 AM
beltrunner
May 17, 2015 10:18 PM
Noenav
Apr 30, 2015 01:06 PM
edman
Mar 13, 2015 09:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
