knock sensor delete question
Old Aug 24, 2005 | 01:54 AM
cammed_aro Z28's Avatar
just wondering if anybody had done the knock sensor delete where you put the resistor on the wire to the knock sensor and ground it. wondering if it works, i keep springing header leaks and all kinds of other crap and i think it is making the Knock sensor freak out, just wanting to try that to see if the sensor is my problem. also does anybody know if by doing that does it give you the max potential timing (aka no retard at all?) thanks in advance
Old Aug 24, 2005 | 10:43 AM
izzyz28's Avatar
Re: knock sensor delete question
I did it to my car about a year ago and it works great! You get the full amount of timing the computer will allow with no retard. I haven't had any problems so far. Just a little pinging if I get a bad tank of gas, which has happened twice.
Digital Designs's Avatar
i had false knock problems before i did this mod. I went to radioshack and got a 3.9k ohm resistor, wired it to ground, then drove it around with a reading of 0 degrees of timing retard from 0rpm - redline.
Old Aug 24, 2005 | 10:51 AM
dreamer1q's Avatar
Just bring the thing over to me and I will program out the Knock Sensor so you dont ever have to worry about it again
HectorM52
Jul 30, 2017 11:46 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
96z
Sep 5, 2002 07:53 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
