Knock Sensor Code. Help Me!!!!!!!
Old Feb 8, 2004 | 05:47 PM
izzyz28's Avatar
Alright, here's the scoop. I was bleeding my cooling system today, because one of my head gaskets is leaking internally, and the car needs to last until spring break. Anyways, I wash off the engine compartment with a hose, start the car, and the SES light comes on and then goes off. It keeps doing this every minute or so. I hook up the Tech 2, and it shows a KS circuit malfunction. Since the car has 113,000 mi on it I figure a new sensor will cure it. Put a new one in, and it does the exact same thing. Scan tool shows the KS circuit jumping from OK to OPEN for a split second every now and then, and then the SES light and fans come on. WTF???? I'm ready to throw a grenade under this POS car.
So anyways, any suggestions. Did water possibly get in the ECM and screw with the Knock Module, or am I missing something here. Please help!
Old Feb 8, 2004 | 05:57 PM
So you are getting a code 43? Probably something wet. You should have 5v on the wire to the sensor and the sensor resistance should be 3300-4500 ohms.
Old Feb 8, 2004 | 07:13 PM
izzyz28's Avatar
Thanks shoebox, I'll check it out tomorrow when I get it back on the lift.
KYWes
Jun 14, 2022 06:52 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
