Knock Retard Suggestions?
Old Jul 28, 2013 | 03:12 PM
  #16
slick1hunting's Avatar
heal quick Fred and Rob. Might be worth poppin the hood in the dark looking for an arcing wire or two. Using a spray bottle with water may aid in getting an arc. Sometimes a quick look from the underside helps too. If you have a IR thermometer you can check for hot cyllinders. They may help and may not but its easy and cheap to do. How did the plugs look?
Posted from Camaroz28.com App for Android
Old Jul 28, 2013 | 03:30 PM
  #17
njmike's Avatar
Re: Knock Retard Suggestions?
The other night I was checking for arcing and unfortunately I didn't see anything. I even jacked her up so I could crawl underneath and get a better look at the plugs. I also checked the wires and their routing. The only thing I didn't do was use a spray bottle with water which is a good idea. I am pulling the plugs as I type and will report back when done.
Old Jul 28, 2013 | 04:08 PM
  #18
njmike's Avatar
After inspecting them all they all look the same and they look good. From what I know they look a little lean but they look good.
KYWes
Jun 14, 2022 06:52 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Jocofire1
Aug 7, 2015 03:16 PM
4586
Jul 31, 2015 06:03 PM
asilomar244
Jul 12, 2015 05:53 AM
