knock retard question
Old Jun 3, 2004 | 07:53 PM
dkeers's Avatar
I'm hunting down some missing horsepower after I got dissappointing times at the track. I finally got freescan to work. I would be glad to e-mail the logs to anyone who would look at them, and thinks they can help (they can be viewd in excel).
I am seeing 7* of knock retard as soon as I go WOT.
Is this the max knock retard that the PCM will allow?
Freescan reports that I am getting 30-32 degrees advance at WOT. Is the retard already subtracted from this? This seems really low.
I belive that it is false knock (I can't hear any pinging) but I am going to fill up with 110 unleaded (I think I can get some around here) to make sure. If I still get that much know retard with the 110, what is the best way to get rid of it. I would like to keep the knock sensor working, but I will disable it if I have to.
Madwolf tuned the PCM, so I assume the spark tables are not stock.
Sorry I have so many questions. Thanks in advance for any help.
Dustin
Old Jun 3, 2004 | 08:08 PM
97s10ondubs's Avatar
have you tried a LT4 knock module first? I'm ordering mine right now.
Old Jun 3, 2004 | 08:34 PM
S8ER95Z's Avatar
When my sensor went bad I believe it was reading 22degrees of pulled timing. I would say 7 is fairly low, and as said above...have your tried a LT4 Knock module yet??
Old Jun 3, 2004 | 10:58 PM
The advance you see already has the knock retard taken out of it. Stock PCM programming can pull as much as 15°. Ion may have limited yours, but only a read of the programming would tell.
maybe2fast
Mar 16, 2015 11:59 AM
mikey4play
Mar 15, 2015 11:45 AM
nophix
Nov 30, 2014 10:26 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
