Knock retard
Old Aug 21, 2006 | 04:57 AM
Geardrive63's Avatar
Knock retard
I've heard alot of various things on the board regarding running the LT4 km etc..
I'm running jet hot long tubes and ive heard often times LTs and exhaust can cause 'false' knock retard.. so i took it to the shop and ran it on a scanner, at WOT i'm showing .7 retard with very little if any retard daily driving. Is this acceptable, or is the KM worth it to get rid of the .7? I think the timing was staying rihgt around 25 which i believe is what the PCM is supposed to keep it at.. will the KM allow it to go farther? is .7 retard at WOT bad, good, or average?
Old Aug 21, 2006 | 05:05 AM
JustNO's Avatar
Re: Knock retard
Knock retard MUST be 0.0
I have the same problem and couldn't figure it out yet! My LT Headers touch my Oil Pan (Canton Problem), and maybe thats could be a false retard. You will be better if you get LT4 knock Module. (to get rid of false knock because of your loud rockers or headers)
Old Aug 21, 2006 | 09:29 AM
Re: Knock retard
You're mixing apples and aardvarks here.... your problems are almost continuous knock retard, including several degrees at idle. That is nowhere near what Geardrive63 is asking about. He has a FRACTION of a degree at WOT only. While the goal is always to have "0" knock retard, you have to be realistic.
The question I would ask Geardrive is WHEN are you seeing that 0.7* knock retard? Its not unusual to see a bit of retard slip in on shifts at WOT.
Old Aug 21, 2006 | 03:48 PM
Re: Knock retard
itr was pretty much throughout the power band at wot, with very little of any retard at just daily driving
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
