Knock Module replacement
Old Jan 9, 2005 | 07:00 PM
kicksZ28's Avatar
Smile Knock Module replacement
Where is the knock module on a 95 Z28 and is it wise to replace it? I have read that the LT4 module is the way to go. If this is true where can one be purchased? My car has 93,000 miles. I have replaced the plugs and coil and will do the wires this week with accels 9000. Thanks
Old Jan 9, 2005 | 07:03 PM
Hawk's Avatar
Re: Knock Module replacement
knock sensor is on the passenger side of the block, under the manifolds or headers.
The lt4 knock module is inside your PCM. The LT4 knock module desensitizes the response to the signal from the knock module.
Brian
Old Jan 9, 2005 | 07:04 PM
unvc92camarors's Avatar
it is wise if you have headers and/or roller rockers
reason is, the stock one will cut back the timing because it's detecting false knock from one of the two above (or both)
it's located in the pcm which is the grey box at the passenger side of the engine bay, all the way in the back, under the cowl sort of
pop the plate off and replace it
just unplug your battery first
i had to charge mine since i didn't unplug it before doing it (always unplug before going into electrical stuff)
Old Jan 9, 2005 | 07:05 PM
o, and you can find it at gmpartsdirect.com
check shoebox's site for the part #
i don't have it offhand
Old Jan 9, 2005 | 07:16 PM
FryedClutch's Avatar
i think its 16114681 for the lt4 km
just installed mine 2 days ago
EDIT pn is 16214681
Old Jan 9, 2005 | 07:44 PM
As an apparent newcomer, you should familiarize yourself with the search. It can answer your questions.
Old Jan 9, 2005 | 10:25 PM
DavesLT1's Avatar
When I looked it up by part munber from Shoe's site it says it is a knock sensor. Is this right?
GM PART # 16214681
CATEGORY: Chassis Wiring & Computer Controls
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $60.83
OUR PRICE: $30.41
DESCRIPTION: KNOCK SENSOR
Old Jan 9, 2005 | 10:30 PM
The only bad info in the link below is the contact number for Cal Slabaugh.... all the other info - part #, location, etc. - is accurate.
http://www.projecttransam.com/projects1.asp
Old Jan 9, 2005 | 10:34 PM
DavesLT1's Avatar
Thanks for the link, if the PN is correct on Shoe's website then I'll order it sometime this week.
Old Jan 9, 2005 | 10:39 PM
If you get the information from Shoebox's pages, it is correct, no question. You need to be sure you understand you need the "module" and not the "sensor".
LT4 knock module - 16214681 - $27.66
Old Jan 10, 2005 | 10:26 AM
DavesLT1's Avatar
On gmpartsdirect.com I think it's about $30. Still sound about right? What I posted earlier was what I got of that site with the part number.
Old Jan 10, 2005 | 02:29 PM
DavesLT1's Avatar
ordered one today. I know it won't show immediate results, but I hope it helps when I have my ported heads in, and I have decided on 1.6 RR's and a cc306.
MadMav
May 25, 2015 09:35 PM
HectorM52
Mar 15, 2015 10:45 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
SC97TA
Sep 15, 2002 01:10 AM
