Knock module OBD-I or II?
Old Aug 21, 2007 | 02:48 AM
z28xlr8s's Avatar
How can you tell what knock module you have? I have a 94 Z
Old Aug 21, 2007 | 03:18 AM
SS RRR's Avatar
Modules aren't OBD specific. Only the knock sensors.
Old Aug 21, 2007 | 03:48 AM
adamc's Avatar
Part No. 16214681 LT4 Knock Sensor Module
Old Aug 21, 2007 | 09:00 AM
z28xlr8s's Avatar
So the knock module plugs in and replaces the knock sensor?
Old Aug 21, 2007 | 11:33 AM
Stl94LT1's Avatar
The knock module plugs into the PCM, and the knock sensor screws into the block.
Old Aug 21, 2007 | 01:48 PM
No, they are two separate parts that work together.
Old Aug 21, 2007 | 05:57 PM
1redTA's Avatar
re
what if you have an OBD-II car(96 Trans Am) and decide to swap to an OBD-I pcm, should you change the sensor then also???? I purchased my pcm from PCM4less if that helps any
Old Aug 21, 2007 | 07:13 PM
SS RRR's Avatar
The only component you need to change is the SENSOR. As stated the MODULE is not OBD specific.
Old Aug 22, 2007 | 08:43 AM
1redTA's Avatar
re
"The only component you need to change is the SENSOR. As stated the MODULE is not OBD specific."
WTF! did I mention the MODULE, I asked about the SENSOR
Old Aug 22, 2007 | 09:32 AM
jasonisdn's Avatar
i run my OBDII sensor in my OBDI swapped car, no issues.
Old Aug 22, 2007 | 04:42 PM
SS RRR's Avatar
I was emphasizing my first post since it answered your question:
Old Aug 23, 2007 | 12:52 PM
Ask pcmforless if he already converted your OBD-I PCM so that it would not need a replacement on your OBD-II knock sensor. He may have already taken car of it.
Old Aug 25, 2007 | 07:48 AM
1redTA's Avatar
re
I read up on the resistor change, and remember that was how it was done. Thanks Art
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
