Preload on GMPP Lifters
Old Aug 3, 2007 | 11:17 AM
96LT1TX's Avatar
Well, I had the comp R lifters for a year or 2, and then they started losing clips. I was used to doing 1/8-1/4 turn when adjusting RR's, and lately they have been coming loose when I go to the track. I thought 1/4 turn would be enough with these lifters, but now I am reading 1/2-3/4 (from one source) turn past zero lash? Is this true? If so how much power is honestly to be gained from doing 1/2 turn instead of around 1/4 turn?
thanks
Old Aug 3, 2007 | 12:51 PM
NJLT1SS's Avatar
On any hydraulic roller that I have had, whether it was using OEM lifters, Comp R's, or Morels, I only go 1/4 turn past 0. What type of locking nut are you using? I have had one or 2 back off in the past, but I would just set it to 1/4 turn preload, and then make sure the lock nut was tight. All would be good afterwards.
Nick
Old Aug 3, 2007 | 01:23 PM
Z-RATED94's Avatar
As you are doing and Nick suggested, 1/4 turn is plenty.
Old Aug 5, 2007 | 10:51 AM
96LT1TX's Avatar
ok cool, I have only had 2 back off since I built new motor, I am using poly locks with my 1.6 pro mags. My poly locks are a few years old, but they still seem to be able to tighten pretty good.
Old Aug 23, 2007 | 10:50 PM
96LT1TX's Avatar
locking the nut seems like it must be where I am making an error and why they are backing out. When I do the lock, I get the preload set (minus like 5 degrees) and then lock the nut, and then tighten the nut as hard as I can with the lock tightened... is this the right way?
thanks
Old Aug 24, 2007 | 10:30 AM
Vicious95Z28's Avatar
I always tighten the nut to were I want my preload and hold it steady with a wrench and then crank on the lock pretty hard. I've had good luck with that.
Old Aug 24, 2007 | 10:58 AM
The Engineer's Avatar
That is the exact same method I use. And, to date I haven't had one get loose (knock on wood). However, I'm usind Crane 1.6 RRs with their poly-locks.
WD
Old Aug 25, 2007 | 07:07 AM
cehan's Avatar
[QUOTE=The Engineer;4825123]That is the exact same method I use. And, to date I haven't had one get loose (knock on wood). However, I'm usind Crane 1.6 RRs with their poly-locks.
WD[/QUOTE
That's the way I've always done it too, except that somewhere I read that the locks should be torqued to 20 ft. lbs., so I use my in. lb. torque wrench (it's smaller and easier to get in at the back ones) set to 240 in. lbs. Never had a problem yet.]
Old Aug 25, 2007 | 08:59 AM
WD
Yep, I've got Comp Pro Mags and I'm using the hardware that came with them, I'm pleased.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 24, 2015 06:41 AM
