what if you have an OBD-II car(96 Trans Am) and decide to swap to an OBD-I pcm, should you change the sensor then also???? I purchased my pcm from PCM4less if that helps any
The only component you need to change is the SENSOR. As stated the MODULE is not OBD specific.
"The only component you need to change is the SENSOR. As stated the MODULE is not OBD specific."
WTF! did I mention the MODULE, I asked about the SENSOR
I was emphasizing my first post since it answered your question:
Originally Posted by SS RRR
Modules aren't OBD specific. Only the knock sensors.
Ask pcmforless if he already converted your OBD-I PCM so that it would not need a replacement on your OBD-II knock sensor. He may have already taken car of it.
