Knock Knock! On my LT1
Old Apr 22, 2006 | 08:36 AM
GREZ28's Avatar
Question Knock Knock! On my LT1
Knocking has started about 2-3 weeks now. I'v had some work done to it on a past oil leak on the timing chain cover at a shop which was last fall. Its not a daily driver. I must have drove it baybe the most 20 times ever since the repair. The noise is a little bit hard to tell the exact location but it sounds like it's in the front of the engine somewere. It won't do it when I start the car, after a five minute drive you will start hearing the knocking noise.
Anyone know what it might be? I do also have march pulleys, do you think that might have something to do with it?
Old Apr 22, 2006 | 08:37 AM
Hawk's Avatar
Re: Knock Knock! On my LT1
well, you can run the car without the serpentine belt to see if the sound goes away. If it does it's one of your accesories.
If not, knock usually is a bad sound, most likely a rod bearing. How does your oil pressure look??
Also, are you sure it's not valvetrain noise(clicking/clacking sounds)
Brian
Old Apr 22, 2006 | 08:48 AM
GREZ28's Avatar
Well I have kept an eye on the oil pressure ever since I noticed the noise, it seems to look just fine.
By removing the serpentine belt you meen just take it off and turn the car on? Should I do that after I start hearing the noise again?
Old Apr 22, 2006 | 08:58 AM
Hawk's Avatar
Yes, when you hear the noise again, take off the belt. THen start the car. If the sound goes away, then it's a pulley, alternator, etc anything hooked to the belt.
Old Apr 22, 2006 | 09:03 AM
GREZ28's Avatar
Ok, I will keep ya posted I will do this later in the day. I hope its a pulley. And yes about the knocking noise its just a clean sound of knock knock, nothing els.
Old Apr 23, 2006 | 09:55 PM
sam pace's Avatar
is the sound rpm related
Old Apr 24, 2006 | 02:24 AM
Rashiki's Avatar
I agree with sam.. Does the knocking get louder/more frequent as RPM increases?
I recently developed a knock as well, but only when warm. Turns out my passenger side heater is knocking against the lower A-arm, when the motor mounts heat up and start to flex a bit and sag. My mounts are shot, and due to be replaced. This should raise the engine back to correct orientation, bringing the exhaust away from the arm, and no knock
Old Apr 24, 2006 | 06:40 AM
30AnvZ28's Avatar
I had a knock... oil pressure was sparatic... main bearing was shot.
MadMav
May 25, 2015 09:35 PM
jayblev95
Dec 1, 2014 06:55 AM
Nostang 96z
Sep 10, 2002 08:54 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
