kNOCK COUNTS GOING TO THE MOON AT IDLE!
Old Feb 24, 2003 | 03:23 PM
SABLT194's Avatar
Just fired back up after a bottom end refresh and the addition of a set of Lloyd's heads. I now have knock counts going crazy at idle and pulling like 12 deg of timing. I installed a new knock sensor at time of rebuild since I destroyed the old one getting it out.
If I remove he sensor wire, the counts stop but PCM still pulls timing (probably a failsafe mode).
Any ideas?
Steve
Old Feb 24, 2003 | 03:33 PM
ablackcamaro's Avatar
Not sure if this helps but I've read that roller rocker arms can cause false knock... is this what was installed in the heads that you put on? You can try an LT4 knock sensor or module... not sure which they use, but I'm sure someone will elaborate for us Good luck either way.
Oh yeah... do the knock counts go away as you go off-idle?
Old Feb 24, 2003 | 07:26 PM
Dave 96TA's Avatar
yes you certainly want to pickup an LT4 knock module - it plugs into the little socket under the small cover door on the PCM. they're like $35 most places, do a search for more detail on how it works.
Old Feb 24, 2003 | 09:19 PM
With the LT4 knock module, is it the same sensor that bolts onto the block? If so, what's the difference, just that the LT4 knock module is less sensitive or something? Again, if this is so, instead of using an LT4 knock module, can you just reprogram the PCM using TunerCat to pull less timing w/ knock or something like that?
KYWes
Jun 14, 2022 06:52 AM
pimpen1024
Aug 19, 2015 08:36 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
asilomar244
Jul 12, 2015 05:53 AM
