kmotion k-800 valve springs
Old Jan 7, 2005 | 09:51 AM
camaroKid223's Avatar
iv been doing alot of research for the cam install that im getting ready to install. the cam is the gm847 and i think the comp 987's are only good to about .600 and i think i may need alittle more lift? i read that alot of guys are using the kmotion k-800's. how much more lift will these hold? how hard are they to set up with the shims vs. any other valve spring?
Old Jan 7, 2005 | 10:24 AM
Compstall's Avatar
Re: kmotion k-800 valve springs
1.460'' diameter double Silicon spring. Valve lift up to .600''. 155# @ 1.850'' closed, 450# @ 1.150'' open, coil bind @ 1.085''.
..that's what Jeg's says.
Old Jan 7, 2005 | 10:35 AM
so with a lift that looks to be the same are the k-800's really any more safe to run then the 987's?
Old Jan 7, 2005 | 11:10 AM
dmoor88's Avatar
depending on the installed height, those springs can be good to ~.700" lift
Old Jan 8, 2005 | 12:55 AM
so these sound like a good spring to run with the gm847 and comp r lifters then?
Old Jan 8, 2005 | 06:06 PM
dmoor88's Avatar
definitely.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
