KEEPING a 96 lt1 transam cool
Old Aug 13, 2008 | 12:42 AM
briggsbuilder's Avatar
Hey u guys i have a 96 transam with a lt1 and a six speed...... ive been having a problem with the car overheating after like 20 min on a hot summer california day.... also ive thrown both fans to come on with switch..
What the best combinations in waterpumps,and radiators that are keeping these lt1's cool?????
Iam looking for some feed back from people that live and drive there cars on very hot days that arent having any issues with over heating
Old Aug 13, 2008 | 02:01 AM
red1984's Avatar
Flush the cooling system out, install a 160 stat, have the fans programmed to come on sooner and/or install and manual fan switch. That might help.
Old Aug 13, 2008 | 02:17 AM
Green96Z's Avatar
If you're overheating after 20 minutes out here, then you have problems with your cooling system. I ran my car stock for months in 120 degree heat and it never overheated.
Old Aug 13, 2008 | 02:18 AM
i have already flushed it out, and also have both fans on a switch, plus i know how to bleed the system so any other sudgestions
Old Aug 13, 2008 | 02:33 AM
red1984's Avatar
How old are the sensors? Are they giving you accurate readings?
Old Aug 13, 2008 | 12:48 PM
I think the sensors are ok because a soon as its starts overheating it leaks a little fluid out from somewere.............
Old Aug 13, 2008 | 01:10 PM
Something is wrong somewhere. The LT1 cooling system is a good one and easily capable of keeping things cool. The system must be tight and in good working order, no blockages in the radiator, air dam on and no debris blocking air flow. A bad head gasket can cause cooling problems, too.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jun 23, 2016 08:42 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Doug Harden
29
Jul 30, 2003 07:05 AM
