K&N on 96-97 SS not recomended
Old Jan 16, 2004 | 10:44 AM
  #16
BUBBA's Avatar
The Jeep filter, which fits, has horizontal pleats which allow the filter to be accordianed (pushed in) whereas the Holley has vetical pleats which makes it more rigid and not subject to being pushed off the base.
Vertical= lllllll
Horizontal= -------
Old Jan 16, 2004 | 10:53 AM
  #17
hairbear21's Avatar
I wonder why K&N hasn't addressed this yet. I bought one for the Bu', and it came with a gasket and a sheet stating that it is a revision and if you didn't use the gasket the filter wouldn't seal correctly.
Interesting.
  #18
Don 97 SS's Avatar
Vertical= lllllll
Horizontal= -------
Yep! Apparently the K&N Filter #33-2084 I had is not the Jeep filter that has the horizontal pleats. It has vertical pleats.
Regardless, I wouldn't recommend the 33-2084, because the Holley is much better (in terms fit and finish)
...and it has vertical pleats!
  #19
96ssz28#395's Avatar
Thanks everyone for the part # Mike.....
Old Jan 16, 2004 | 10:57 AM
  #20
BUBBA's Avatar
ZOSO: I'm not familiar with the TA setup. The straight in approach should be superior to the SS route.
If your filter is catching crap, it is doing its job. If it is REALLY catching crap, then maybe its because of its straight-in approach and location. Don't know.
Probably someone else with that setup will be able to help you out.
Old Jan 16, 2004 | 11:03 AM
  #21
zoso1959's Avatar
A THOUGHT
Thanks bubba
I was just wondering how different the t/a ram air set-up and ss ram air set-up?
the filter is is catching crap
thanks
zoso
Old Jan 16, 2004 | 11:49 AM
  #22
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Back when my car was naturally aspirated (and still using the SS airbox), it made 452rwhp with a new fram filter, and 452rwhp with a new K&N filter.
Old Jan 16, 2004 | 11:52 AM
  #23
Z28SORR's Avatar
This has been discussed on this, and other boards many times.
KN-33-2018 will fit perfectly. See here, http://www.lgmotorsports.com/OCLT1_Fbody_Induction.htm
Whether the pleats are vertical or horizontal they wont get "sucked in" unless you never clean it.
I have used this filter for over two years with NO problems.
Oh, and this is not an ad for K&N just info.
Old Jan 16, 2004 | 07:04 PM
  #24
fozziez28's Avatar
So whats the verdict? I have a k & N in mine with horizontal pleats. Do I really need to change it or will I be good? Ill have to dyno with and without and see if there is any difference. -Michael
GREEN3112
Feb 10, 2019 09:19 PM
Ringmaster72
Dec 12, 2017 10:12 PM
Sauced
Apr 12, 2015 10:18 AM
Cream
Jan 28, 2003 05:53 PM
TA76
Dec 10, 2002 10:21 AM
