K guys......lets go... SYNTHETIC or Regular Oil?????
Old Aug 29, 2003 | 12:08 PM
  #16
Terran2k's Avatar
run dino oil on your new motor for the 1st 3k miles or so and change it a few times between then, then switch to mobil 1 syn, thats what i'd do anyway.
Old Aug 29, 2003 | 03:45 PM
  #17
Patman's Avatar
Originally posted by LeftoverChinese
I drive about 100+ miles every day, so I'll hit the 5k barrier real quick, would you like me to send you a sample of my oil so that you can run a test on it? Shoot me an e-mail and I'll see what I can do, I would like to hear what the numbers come out as too.
It would be easier for you to send the oil to the lab yourself, since sending it across the border can sometimes be tricky. Check out Blackstone Labs, they are very good. (do a Google search for their website address)
If you're doing 100 miles a day or more, you'll probably find that you can go way longer than 6k between changes, probably closer to 10k or more.
Old Aug 29, 2003 | 05:09 PM
  #18
Carlos01SS's Avatar
I've heard the same thing, with a new/rebuilt engine to use conventional oil, change it @3000 miles, use conventional oil for the the next change. On the 3rd or 4th oil change, then switch to synthetic.
A couple of mechanics told me the same thing, with new engines, conventional oils help "seal" the gaskets during the first 5000-10,000 miles, then switching to synthetic.
I don't know if this is true or not, the mechanics I've spoken to say that the conventional oils get somewhat gummy, which help seal the gaskets??? That is why most folks say not to change to synthetic oil on engines that have high mileage, they find/make openings in the gaskets...???
Old Aug 29, 2003 | 05:29 PM
  #19
red's Avatar
red
You are thinking of the rings. With synthetic it is possible that the rings will not seat properly on break in. That is why many builders suggest Dino on break in and synthetic after. The gaskets do not need anything to help them seal.
Old Aug 29, 2003 | 06:11 PM
  #20
Patman's Avatar
Rings will seat just fine using synthetics, otherwise there would be a lot of problems with all of the Corvettes built since 1992.
Contrary to popular belief, synthetic oil is not more slippery and does not hinder the break in process at all. I know people who have converted their new cars over to synthetic oil the same day they picked them up, and have no oil consumption issues.
The only reason to stick with dino oil in a new engine is so you can do a few frequent changes at first and not spend a lot of $$$ on oil you're going to just drain out quickly.
Old Aug 29, 2003 | 06:47 PM
  #21
TMDZ28's Avatar
just use regular oil plus 1qt of marvel mystery oil....people says it works like a charm
Old Aug 29, 2003 | 07:13 PM
  #22
Patman's Avatar
If you want to thin out your oil that is. I'd never recommend doing something like that at all.
Old Aug 29, 2003 | 10:06 PM
  #23
S.J.S.'s Avatar
well I'm building a 383 and was wondering what kind of oil to run in it.
Old Aug 29, 2003 | 11:22 PM
  #24
TMDZ28's Avatar
are you serious?? because i just refund my mobil1 fully syn. and bought 5qt of valvoline regular oil, and 1qt of marvel mystery oil.....are you serious?? a good friend of mine recommended me using this....
Old Sep 1, 2003 | 02:26 AM
  #25
S.J.S.'s Avatar
Guess I'm gonna use mobil 1. You know I've heard guys using different weight oils and not going with the 10-30 just the plain 30. Any comments on that?
Old Sep 1, 2003 | 09:04 AM
  #26
FastZinTennessee's Avatar
I don't think you can get mobil 1 synthetic in straight 30 wt.
rideordie
Nov 5, 2019 04:52 PM
SergheiS
Jul 5, 2015 03:27 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Nickster 7
May 1, 2015 09:04 PM
ssbee
Jun 12, 2002 12:03 PM
