Just use a caliper to measure crank gear to cover depth
Subscribe
Feb 6, 2006 | 12:43 AM
I seem to have misplaced my crank hub bolt, but if I don't find it, I do have the part numbers. I haven't yet installed my hub, but I did paint-mark it with victory red touch-up from my caliper setting (that I inserted untill it bottomed on the crank gear). My installation will include a cut to 8" long
7/16"-20 grade eight all thread with thick washers and grade eight nuts (bought from a local McFadden-Dale Hardware). I'll heat the hub in the oven to about 250 degrees, then use my home-made installer untill the paint mark lines up with the seal face. Even though I have a plan, I am still creeped-out because I've read at least fifty threads in the past weeks. Thanks for all the info!
Reply
Feb 6, 2006 | 01:50 AM
Re: Just use a caliper to measure crank gear to cover depth
Quote: I seem to have misplaced my crank hub bolt, but if I don't find it, I do have the part numbers. I haven't yet installed my hub, but I did paint-mark it with victory red touch-up from my caliper setting (that I inserted untill it bottomed on the crank gear). My installation will include a cut to 8" long
The hub needs to bottom out on the timing chain sprocket where ever it winds up. If it's to far in then ya need a shim.To far out ya need to cut the hub or get another balancer.The belt alignment will tell ya that.
Reply
Subscribe
