Just Sea Foamed car...No smoke!!
Old Jan 11, 2004 | 06:32 PM
95RagtopTA's Avatar
I was already to smoke out the neighborhood next to me but no smoke . I let the car warm up, put 1/2 can in through the middle L-shaped tube on pass. side of throttle body (had to turn off car b/c it wouldn't die), then put other 1/2 can in oil. While I was waiting 15 minutes I sprayed deep creep in the throttle body. When I started the car (took a couple of tries), a lot of blue smoke came out, then it cleared right up. Ran the hell out of the car for 20 minutes...Never smoked. My car has 80k miles on it...can't imagine it's that clean!!!
Old Jan 11, 2004 | 06:35 PM
My95Z's Avatar
either your car i srelly clean.. or your cat and muffler are really clogged and are holding all teh smoke in..
Old Jan 11, 2004 | 07:05 PM
unvc92camarors's Avatar
you might want to check your o2 sensors on a side note
supposedly sea foam kills them somehow after you do it, not that that has any bearing on no smoke
also, you should be putting it in your oil about 500 miles before you change it
that way it can get all the crap out and be sitting in the oil pan waiting for you to change it
but really, i havent seen too many cases of no smoke
what's blue smoke again? i know white is oil burning and black is unburnt fuel...
Old Jan 11, 2004 | 07:14 PM
hsyr's Avatar
Actually, blue smoke is oil burning, white is coolant, and black is a rich condition.
Old Jan 11, 2004 | 07:21 PM
95RagtopTA's Avatar
yea, the smoke was definately blue...never saw white. Kind of strange when I started the car--heard a bunch of popping noises coming from the cat. I checked and it appears the exhaust is flowing normal. Car is running fine, I just expected a lot more smoke. Perhaps it didn't smoke much because I was unable to flood/stall the car??
Old Jan 11, 2004 | 08:09 PM
ChickenScreamer94's Avatar
if you put it in the L shaped tube on the TB or the valve cover then i think you jsut put more into your oil THat is part of the pcv system. You need to put it in on the brake booster line.
Old Jan 11, 2004 | 08:24 PM
kgkern01's Avatar
^There is a vacuum into the side of the TB also. Thats where I seafoamed mine back in the summer, smoked up the neighborhood
Old Jan 11, 2004 | 08:47 PM
Seal's Avatar
I wouldnt put it in my oil system... the sludges might clog the oil lines, and that wouldnt be nice
Old Jan 11, 2004 | 09:30 PM
aaaah, i'm a little rusty
atleast mine doesn't have any of those symptoms
so yea, i gues you're burning oil dude
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
alphaauto
Jul 26, 2015 04:40 PM
