just reinstalled intake, new problem
Old Apr 13, 2007 | 07:42 PM
MTBeni's Avatar
Like it says, I pulled the intake finally to fix that rear leak. I hope it doesnt leak anymore cause I had a hell of a day doing that. Everything that couldve went wrong did. I did an EWP too and that didnt help my case. Anyways, got it all back together BUT
1. The vented opti has 2 hoses coming off of it in the same loom. 1 goes to the intake...what about the other. I cant find a vac port anywhere that it would go to. I looked at shoeboxes site but it wasnt clear where it went.
Thanks guys!
Old Apr 13, 2007 | 08:02 PM
SS RRR's Avatar
The 2nd hose goes to the top of your bellows. Should be a blue plastic elbow coming off either the bellows or the vacuum tube.
That way it draws filtered air into the opti.
Old Apr 13, 2007 | 08:34 PM
MTBeni's Avatar
Its the other hose. The one you mention is installed in my ram air box.
Old Apr 13, 2007 | 09:28 PM
SS RRR's Avatar
Then you answered your own question. There are only two hoses. One goes into your bellows/box and the other goes to a vacuum port on the drivers side of the intake.
Old Apr 14, 2007 | 07:02 AM
MTBeni's Avatar
ok, I guess Ill have to find where it goes on the intake then. I looked all over and couldnt find a vac port for it. Gues I have to keep looking. Oh, I also have a coolant leak coming from the top large hose where it meets the waterpump. Hopefully its just not seated all the way or something. Thanks
Old Apr 14, 2007 | 07:28 AM
mobleman's Avatar
The second hose (with the small plastic check valve on it) goes to a vacuum port on the manifold on the driver side.. It's kind of hidden under the mess of other injector wires and vacuum lines.. See this pic on shoebox's website:
Click on "N1" in the diagram below:
http://shbox.com/1/devices.htm
To see this view of the vacuum line right next to the PCV valve:
http://shbox.com/1/pcv.jpg
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
beaver50
Feb 15, 2015 02:56 PM
mattszm6
Dec 14, 2014 07:09 AM
slothgrant
Aug 22, 2002 03:01 PM
