just a little help please...
Old Mar 17, 2003 | 06:01 AM
Mike Meyers's Avatar
OK, first time driving the car or even looking under the hood in about 6 months, so I'm a bit rusty....
1. I've got a dummy light on my dash that's lit up. Wasn't lit when I stored it. Red, with water? and a down arrow. Is this a low coolant indicator? It's not oil. Oil says LOW OIL....
2. Popped the hood, look around and saw a sensor wire/clip/whatever hanging free. Obviously it should clip into something. It's coming from the drivers side wheelwell area, just under the ABS junk. It's got a purple housing, is oval shaped and has the female side of a 3-pin connection. It's possible that this was just left over and unnecessary since I removed my stock intake and went with the ram air lid. My MAF is plugged in, my coil is plugged in, my head coolant temp sensor is plugged in, etc. I can't see anywhere to plug this thing in You guys with stock air intakes... is this something that you still have hooked up? WHAT IS THIS CLIP!?!?!
Thanks.
Feels good to be driving the car again, even with problems.
Old Mar 17, 2003 | 06:29 AM
Josh-'04 GTO's Avatar
Sounds like the low coolant light. You can check almost directly behind the radiator cap about 6 inches down is the coolant level sensor, it may have come unplugged or maybe you just need some coolant.
As for the other connector thats loose, maybe the oil level sensor connector?
Old Mar 17, 2003 | 09:26 AM
If it was the oil level sensor... where would it plug in?
thanks...
Old Mar 17, 2003 | 10:27 AM
Smoke T/A's Avatar
Well the plug sounds like it goes in to the air pump if it directly below the abs module. The light is low coolant. Its a square light with a down arrow and waves.
The Oil level sensor plugs in to the sdriver side of the oil pan right above the drain plug. HTH
Joe
Old Mar 18, 2003 | 06:37 AM
Joe
God, I feel like such a tool. I'm assuming my airpump is gone when I yanked all of the EGR stuff for my longtubes? So I don't need to worry about this clip then?
I looked at a buddy's 97 and wasn't able to find the same wire or clip....
Old Mar 18, 2003 | 10:41 AM
96speed's Avatar
Cool
Loose Connector - Its the airpump connector which you dumped when you installed longtubes .
Ryan
Old Mar 18, 2003 | 11:13 AM
Smoke T/A's Avatar
Ryan
Ditto
Old Mar 18, 2003 | 02:13 PM
any problems with me just snipping that wire where it comes out of the wiring harness?
Old Mar 18, 2003 | 02:19 PM
dabear95's Avatar
If you ever needed that wire, then yes.
Old Mar 18, 2003 | 05:46 PM
Smoke T/A's Avatar
I would just run it behind the ABS module to where it is hidden. You never know if you will use it again.
Joe
munchoman5001
Jun 30, 2007 10:36 PM
Longhorn450
Parts Wanted
Jun 19, 2007 07:56 PM
ILYA
Apr 23, 2007 12:05 PM
PacerX
80
May 11, 2005 02:50 PM
