Auto Tranny Isuues...
Old Apr 22, 2007 | 02:13 PM
ILYA's Avatar
So I ve had my car running for an entire 10 miles before more issues...
95 Z28 Recent work : Accel opti and wires, NGK plugs, GMPP water pump, GMPP LT4 timing set, fuel filter, intake gasket, etc... Before i got it, it seems to have had minimal maintanence, so i am assuming the tranny filter and fluid are still original...
Last night I got an itch to floor it after turning a street corner (so it was prolly in second) - it revved up to about 5000 rpms, then i heard a poping sound somewhere, and the tranny did not shift until i let go of the gas pedal... i drove for about 3 miles normally (at about 45mph), it shifted, but i thought that it was starting to run funny... I stopped for 10 minutes, restarted again and drove home for another 3 miles (at about 35 mph)...
it progressively became worse, bogging down and hesitating, doing kangaroo-jumping when given gas, and not shifting till higher rpms than normal... when i was almost home it got real bad, but it made it back... when i turned it off i saw some smoke inside the cab, probably coming through the shifter console openning from the tranny...
first i thought that i probably blew a line, so this morning i looked for leaks and checked the fluid - it all looks fine, although the tranny fluid looks not bright red, but kinda browninsh and smells a little burnt (but not that bad)... drove it (while it was cold) around the block, still has hesitation and serious lack of power...
so what could it be? plugged up filter or lines? torque converter? burned up clutches? what else? any testing i can do to narrow it down?
is there any way to diagnose with an aldl cable - if so, software recomendations please...
Old Apr 22, 2007 | 02:20 PM
mdacton's Avatar
datamaster has a free trial...see if you have any codes first, sounds like its shot,
Old Apr 22, 2007 | 02:35 PM
ILYA's Avatar
i just tried Datamaster EE, still have to figure out how to scan for codes tho...
Old Apr 23, 2007 | 12:05 PM
12SCNDZ's Avatar
If the fluid is that bad, you may be looking at a rebuild. The "lack of power" could be a "tie up" in the transmission, or it may be starting off in the wrong gear.
Frank
CPT
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
colts0455
Jul 24, 2015 04:51 PM
Jul 17, 2015 02:47 PM
GT what?
Jul 14, 2015 10:17 PM
Jul 10, 2015 02:23 PM
