Just got a scanner.....wondering about the results
Old May 19, 2005 | 04:02 PM
  #16
My Iroc Z28's Avatar
Re: Just got a scanner.....wondering about the results
Originally Posted by Injuneer
Absolute TPS: 0.0 - its sitting there idling and your throttle is closed - NORMAL
Engine RPM: 750 - hopefully you have an M6, because that's too high for an A4
Calculated Load: 2.4 - 2.7 - it takes 2% of the power to keep the engine idling, no an important value
MAF: 0.9 - 10.5 - Do you possible mean 9.0 to 10.5 gps? That would be slightly on the high side. But 0.9gps doesn't make any sense at all, unless the engine was about to stall.
MAP: 10.6 - Your pulling about 19.5"Hg of vacuum - NORMAL
Coolant Temp: 172* - self explanatory
IAT: 117* - your inlet air temp sensor is showing signs of heat soak, since I doubt the local air temperature was 117degF.
Ignition Timing Advance: -18 - -22 - Normal for idle
Second Air: Atmosphere (No idea what that means)
LT FTRM1: -15.6 - Your engine would be running rich on the drivers side, so the PCM is pulling out 15.6% of the fuel it would normally calculate for the MAF air flow you are seeing. That's not good. Shouldn't need to tweek the fuel by more than +/-5%. Since your MAF flow is on the high side, is it possible you have the screen out of the MAF sensor?
ST FTRM1: -3.9 - -6.3 - doesn't mean much in a single frame of data
LT FTRM2: -8.6 - Again, it would be running rich on the passenger side, but the PCM is pulling out 8.6% of the fuel to compensate. You have "split" BLM's..... for some reason the left and right banks of the engine are out of balance on A/F ratio control
ST FTRM2: -1.6 - -3.1 - see above
O2S11: 0.260 - 0.435 ***
ST FTRM 11: -3.1 - -5.5 - see above
O2S12: 0.395 - 0.895***
O2S21: 0.320 - 0.470 ***
ST FTRM 21: -1.6 - -2.3
O2S22: 0.420 - 0.870***
OBD2: CA
***The nomenclature on the O2 sensors are unclear. The limited swing on O2S11 and O2S21 would appear to be for the after-cat sensors. If that is how the scanner indicates the after-cat sensors, they are NORMAL.
O2S12 and O2S22 appear to be the pre-cvat sensors, and the results look too limited. But you can't even see the actual O2 sensor values. In actuallity, the O2 sensor millivolts are changing almost 10 times a second, so the scanner won't even be able to show you all of them. Again, this is meaningless in a single frame or two of data. If you looked at it for 5 minutes, and the pre-cat O2 sensor NEVER went under 420mV (0.420 volts), you have a problem. They should be swinging from below 0.100V to more than 0.900V. If they never go below 420mV, it would be confirming a rich condition that the PCM is working to correct.
Obviously, grabbing a few numbers off a hand-held is not going to show you a lot of info. A running data log would tell you a lot more. It also seems like the Actron 9145 is very limited in the parameters that it can scan. Does it not have a way to display the "enhanced" parameters? That's were a lot of valuable data it sitting.
hey injuneer. you said spark advance for idle should be -18 through -20 correct? well i hooked up my solus to my 97Z and im at a +20 @ idle. is this ok? i have a mad Z tune so im not sure if he put it this way but i just feel like my car has lost the power it did when i first installed my LT's with my ory.
Old May 19, 2005 | 04:35 PM
  #17
Originally Posted by kevm14
Here's a thought. Does 100% DC really correlate to static injector operation? I don't think it does...the calculated DC that we use is based on crank degrees (related to rpm and the duration of the intake stroke). So can't an injector stay open beyond the time the intake valve closes and go above our calculated 100% DC, even though it's still not static? It wouldn't be the best fueling, but it would load up the manifold and vacuum would pull the mixture where it needs to go. Might explain it.
Duty cycle is calculated by dividing the pulse width by the time it takes the crankshaft to complete 2 revolutions. In a 4-stroke engine, when the injector pulse width is 20mSec, and it also takes 20mSec to complete 2 crank revolutions (6,000rpm), the injector is essentially staying open full time. The duty cycle is not referenced in any way to the valve being opened. At WOT the injectors spray for a large part of the time when the valves are closed. In a batch fire setup, like the 93, the injectors on each bank of the engine fire simultaneously on each crank rotation. Most of them are firing against a closed valve. The fuel hits the hot valve and vaporizes, sits there waiting for the next flow of air.
There is an advantage to sizing the injectors large enough to spray "mainly" when the intake valve is open. That allows you to take advantage of the injector timing tables in advanced ECU systems like the MoTeC. But that's for engines operating under extreme conditions, where its desirable to squeeze out the last HP or two.
Different scanners report spark timing in different ways.... some use a "+" and some use a "-". If your spark was 20deg "after" TDC at idle, it probably wouldn't idle at all.
Old May 19, 2005 | 05:32 PM
  #18
thanks, also im hear to report that my LT's with the LM is pulling 10 deg of timing. i so i found my power loss, if anyone's got a LT4 KM for sale or trade pm me details
Old May 19, 2005 | 06:17 PM
  #19
RedRyder518's Avatar
From the Actron scanner, how can I tell if the car is pulling out timing (retard) from the "Ignition timing advance" display? Is there a way I can tell from that?
HAWG
Sep 25, 2015 11:41 AM
Aug 17, 2015 09:50 AM
Boss002
Jul 24, 2015 10:47 AM
