Just got dyno'd
Old Jan 7, 2008 | 06:05 PM
awdfun's Avatar
Just got dyno'd
I was a little dissapointed on my numbers but there is room for improvement.
383
GM847
Ported LT1 Aluminum Heads
1.6rr
6 speed
PCMforless tune
381.1 @ 4100 TQ
333.4 @ 5100 HP
Old Jan 7, 2008 | 06:08 PM
MeanGreen97Z's Avatar
Good numbers! AFR?
Old Jan 7, 2008 | 06:10 PM
Pyrodawg's Avatar
good numbers? uh... an 847 alone revving high enough should make 330whp... add a 383 plus ported heads and that number should jump by at least 50
Old Jan 7, 2008 | 06:12 PM
mdacton's Avatar
well start listing parts....post a graph, thats terrible. I made that with Lt's and a hot cam with no tune......
awdfun's Avatar
I have a Dynojet wideband installed on the car but did not log it during the run. But it runs around 12.1-.2 @ wideopen
Old Jan 7, 2008 | 06:21 PM
slomarao's Avatar
you need to spit out more info than that. We need to know everything about your car. Everything!.
Old Jan 7, 2008 | 06:26 PM
remaxracer45's Avatar
shouldn't that be a 420RWHP car? I'm afraid to dyno mine in the spring cuz i'm thinking my set should be 420 or so, am I dreaming?
Old Jan 7, 2008 | 06:34 PM
Ya good numbers... we have no idea what else he has and can only assume that is all that is in the motor. 380 on a base dyno is a good number to work from if you are in the early stages of a build.
Old Jan 7, 2008 | 06:38 PM
awdfun's Avatar
Okay Here is everything i can think of
Will post graph tomorrow
Engine:
383
SRP -12cc Dish Pistons
Eagle Rods 6" Rod
Eagle Crank 3.75 Stroke
Splayed Caps
GM847
LT4 ED Timing Chain
LT1 Ported Heads
MSD Opti Cap and rotor
MSD Coil
30lb SVO Injectors
3.5" Maf
52mm TB
EGR Delete
LT Headers into 2.5" Catted Exhaust Magnaflow Mufflers H-pipe
1.6RR
Crane 10308 (I think) Valve Springs
Jegs SFI Balancer
Milodon Windage Tray
ARP Head Studs
ARP Main Studs
Felpro 1074 Head Gasket .039
PCMforless tune
Drivetrain:
T56
Stock Flywheel
Zoom Clutch
Ford 9" 3.70
31 Spline Moser Axles
Dynapack Dyno
Old Jan 7, 2008 | 06:45 PM
mdacton's Avatar
9" will take some.....no big deal.
Why are you running that piston? its killing you...if this is a N/A or nitrous engine go with a flat top -5cc or something
Old Jan 7, 2008 | 06:47 PM
dangalla's Avatar
if your rods and crank are forged that would be a nice FI setup, that would change that dyno a bit
Old Jan 7, 2008 | 06:50 PM
mdacton's Avatar
What more info can you give on the cyl. heads?
Old Jan 7, 2008 | 06:51 PM
SS MPSTR's Avatar
blocked decked?
Old Jan 7, 2008 | 06:59 PM
who did the porting? don't LE1 packages on a stock block with supporting mods put up 380?
Old Jan 7, 2008 | 07:03 PM
awdfun's Avatar
Originally Posted by SS MPSTR
blocked decked?
yes
