Just got car back from Speed Inc.....
Old Jun 5, 2003 | 03:19 PM
  #31
Tekprodave's Avatar
Wow, that is good. How much HP do you figure the stock crank will hold? I'm looking to get 800hp at the motor, 600-650hp at the wheels w/power adder someday. Should I get a forged crank? If so, I might as well get a stroker huh?
Old Jun 5, 2003 | 03:53 PM
  #32
Chris'SS #2152's Avatar
Well, if you looking into something like that your engine builder will steer you in the right direction.
Old Jun 5, 2003 | 04:07 PM
  #33
HardcoreRM125's Avatar
Wouldnt you be getting alot more then 600RWHP if you was 800 FWHP ? i figured itd b more like 700 RW if its 8 at the fly
Old Jun 5, 2003 | 04:19 PM
  #34
Jesse_Boyer's Avatar
either way, 700 or 800 fwhp will most likely have to be done with a forged crank
Old Jun 5, 2003 | 04:27 PM
  #35
Gripenfelter's Avatar
Going to a 383 would basically just give you more torque and less cam lope. The longer stroke would swallow some of the cam.
Old Jun 5, 2003 | 04:33 PM
  #36
Tekprodave's Avatar
Thumbs up
That's what I was planning but thanks for the info. With my extremely tight budget, I'm always looking to save some dough.
I'm looking for 9's so I'll need at least 600hp at the wheels.
Old Jun 6, 2003 | 08:11 AM
  #37
IDOXLR8's Avatar
Depending on your raceweight you are going to need more than 600 rwhp to get in the 9's . Going in the 9's is not cheap, so you better have a good size budget.
Old Jun 6, 2003 | 08:47 AM
  #38
Originally posted by IDOXLR8
Going in the 9's is not cheap, so you better have a good size budget. [/B]
You got that right. Going 9's is big money not to mention money for when you break things..
Old Jun 6, 2003 | 10:20 AM
  #39
Tekprodave's Avatar
He he. I have had a big emphasis on wieght reduction so that I don't need as much power and things are less likely to break. The 600hp figure is based on a 3000lb raceweight and a 9.94 run. But I'll prolly shoot for around 650hp just to be sure.
Old Jun 6, 2003 | 11:34 AM
  #40
Thumbs up
Well weight reduction is the best start and since you're only looking for 6-650 that should be easier to do. Good bottom end, heads, and n20.
Old Jun 6, 2003 | 12:02 PM
  #41
IDOXLR8's Avatar
Good luck on acheiving your desire raceweight.
Old Jun 6, 2003 | 12:38 PM
  #42
Tekprodave's Avatar
Thanks, I'm real close to being there now but I have to add a cage and other heavier items like a 9" rear so the hard part will be trying to maintain the low weight.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
