Just got 96 SS, needs clutch, but what's this mean....?!
Old Jul 8, 2004 | 11:18 AM
Johnny I's Avatar
I knew it needed a clutch when I bought it 2 days ago. But it makes a grindy/shaky sound when you step on it more than a little bit in almost all gears. For example, Im cruising down the outer road and 35-40mph....I get into the gas a little, without changing gears, and it shakes the stick in my hand and I feel and hear a general shaky/grindy feeling....what's that mean? Is it the bad clutch or something worse? Any help appreciated. By the way, the car has 83500 on the clock and appears not to be driven too harshly.
John
Old Jul 8, 2004 | 11:52 AM
Munson's Avatar
congrats on your ss! i love mine they look badass. i have an a4 so i wouldnt know what it means.. goodluck with it
Old Jul 8, 2004 | 11:56 AM
Johnny I's Avatar
Thanks a lot! I love EVERYTHING about the car!
John
Old Jul 8, 2004 | 12:37 PM
joeSS97's Avatar
It sounds like a warped flywheel and pressure plate.You can have the flywheel resurfaced and install a new clutch,it should solve the problem.
Old Jul 9, 2004 | 12:01 PM
Johnny I's Avatar
That's what I kind of figured, I just don't have much experience diagnosing 6 speeds and v8's yet. It will go in the shop next week.
Thanks,
John
Old Jul 9, 2004 | 12:17 PM
ReducedFat's Avatar
It's probably one of the things mentioned above, but what you said about the stick shaking and the grinding sounds an awful lot like a busted/worn transmission mount. You might want to check that, because if that's the problem it's only a $15 fix.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
