Just finished cam install! XE 230/236
Originally posted by Z95m6
here is the link to the thread.
http://web.camaross.com/forums/showt...obe+separation
and here is the quote from mind game.
"There is a graph showing 3 different cams, one is 'optimal' at 108º another is at 106º and the last is at 110º. The torque peak is about 380 with both the 106 and 108 LCA cams and about 360 ft.lbs with the 110 LCA. The hp peak for 106 and 108 are also almost identical at a 6k peak just shy of 360 hp with the 110 cam just shy of 340.
Just some stuff to ponder.
-Mindgame"
-Mindgame"
-Mindgame"
-Mindgame"
So what effect does this have on our cams?? Aren't most of ours ground in @ 4* advanced? So effectively, those w/ a 110lsa and 112lsa are essentially @ a 106 +4 and 108 +4... Respectively....
Patrick - glad your car is still running
! I sure hope that valve train quiets down some. Dayumn!! your car is loud!
I'm about to pull my covers off and install some valve lash caps. Looked all over today for a set of 7.150 pushrods... Couldn't find any, only choice left was to run valve caps.. They'll give me the .050 I'm looking for. I was getting major valve float @ 6k - never did get a chance to dyno it. Guess I'll play w/ shift points on the track tomorrow
.See y'all there!
PS - thanks Seth @ cmotosports.com for all the help once again!!
The valvetrain has quited down now.
But the car is louder!
You get those caps in yet? I beat a Geo Metro today. It was the LSi model.
I am going to take my car out to the dyno in two weeks.
Patrick
I am going to take my car out to the dyno in two weeks.Patrick
Originally posted by 97Z-M6
real qiuk did you flow the heads if so what are the flow numbers.
Richardan15
May 30, 2015 08:36 AM
F(ast)-body
Feb 26, 2003 09:05 AM
But if not you can come over and hear it. You should hear Shawn 97 Z28 M6's car he has the 230/236 .598"/.608" on a 110!
