just dynoed my minor bolt-on '93/#'s inside!
Old Sep 15, 2004 | 05:29 PM
street demon2k3's Avatar
just got back from the dyno a half hour ago, and i was pretty impressed. the shop that did it usually dynoes mustangs and LS1's. i asked him how much he thought i would dyno and he said around 220-230. i was like alright maybe he's right. first run i went with cutout closed through an LS1 muffler and 2.5in pipes, then after a 15-20min cooldown i went with the cutout open.
first run: 269.1@5300rpm/253.57@5100rpm
second : 284.45@4100rpm/269.44@4600rpm
it was f#cking hot inside the building, easily 100*+. i am pretty happy, because this guy who has a full bolt-on/cam '98 mustang only went 296hp. he asked me what i had in my car, i told him i just had a filter and cutout he saw my dyno sheet and he was like i told him i was going back in a few weeks after i get my LT's and a chip, which should put me close or at 300hp. what do you guys think??? i'll post up the dyno sheet in a while.
Old Sep 15, 2004 | 05:30 PM
Kataklysm's Avatar
Re: just dynoed my minor bolt-on '93/#'s inside!
Not bad at all.
Old Sep 15, 2004 | 05:34 PM
stereomandan's Avatar
Which numbers are the Torque and which are the Horsepower? The numbers look weird to me.
Dan
Old Sep 15, 2004 | 05:39 PM
scyzoryk's Avatar
There is something wrong with that dyno. you sould have easly over 300RWTQ!!!!
Sebastian
Dan
Old Sep 15, 2004 | 05:43 PM
madwolf's Avatar
Yea, there's definetely something wrong with those numbers. (dyno) The TQ RPM is high on the first run and then on the second run, the HP RPM is low.
RamAir95TA's Avatar
Something is definitely wrong. Which one is your torque? Even so, the RPMs don't make sense.
Old Sep 15, 2004 | 06:03 PM
kevm14's Avatar
He'd be trapping well higher than 97mph with that kind of HP. I agree the torque numbers are low, and the rpms seem high. The 2nd run's hp and RPM are flat out impossible with a near stock engine. Something's either up with the dyno or the interpretation of the numbers (torque converter effects maybe).
Old Sep 15, 2004 | 06:20 PM
maybe i posted the #'s wrong or something but anyways here's the graph:
http://memimage.cardomain.net/member...30_18_full.jpg
as for the times in sig dont pay any attention to those i was spinning through 1st and 2nd and had to get off the gas twice to keep the car straight. i know my car has a little more in it
Old Sep 15, 2004 | 06:23 PM
RamAir95TA's Avatar
You have your numbers mixed up.
253HP/269HP run #1.
269HP/284HP run #2.
What was the difference between the two runs? You gained 16HP and 15tq. on the second pass.
EDIT: Nevermind...I see you opened your cutout.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
fift5
11
Oct 1, 2015 10:31 AM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
