Just dies whats up with that??
Old Apr 12, 2010 | 09:30 PM
1nicelt1's Avatar
Well went out to move my car over to make room in the garage and I backed it out starter fine then I tried to back it back in and it just died and check gages light came on it cranks up and starts for a second than just dies what could be the problem?
Old Apr 12, 2010 | 09:51 PM
94CamaroZ28/SSClone's Avatar
It could be alot of things.
Old Apr 12, 2010 | 10:14 PM
Does it have fuel?
Old Apr 13, 2010 | 10:08 AM
craby's Avatar
^^^x2 make sure u have gas in the tank. if yes then listen for the fuel pump coming on when u first turn on the key. if yes then check fuel pressure. if good check for spark at the plugs. if good then pick up a noid light for the injectors and see if there getting told to fire fuel to the cylinders. try and let us know what u find.
Old Apr 16, 2010 | 12:49 AM
1nicelt1's Avatar
It has a little above half a tank so i dont think thats it and it has new spark plugs and wires.
Old Apr 16, 2010 | 09:08 AM
You indicated the "check gauges" light came on - that's what led me to ask about the fuel. The check gauges light would only come on if one of the gauges was out of acceptable operating range. What does the voltage gauge read?
Or do you possibly mean the "SES" light was on? If so, check for codes.
Old Apr 19, 2010 | 02:45 AM
1nicelt1's Avatar
it started back up but has a rough idle and it was the check gages light on befor all this the ses light would pop onon from time to time didnt look at the voltage ill check that today.
Old Apr 19, 2010 | 05:21 AM
Pull the codes. If "the ses light would pop onon from time to time", the code is still stored in the PCM, unless you cleared it.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
