just did a 383 rebuild and it pings.
Old May 25, 2003 | 03:13 PM
yorkie's Avatar
I redid the engine to a 383, it has -12cc pistons, like 10.8:1 compression, I have had it tuned by pcmforless.com, has 46-47 psi fuel press with the vac tube off, on shifting from 1-2 with a light load it pings (sounds like marbles in a tin can), some times it does it some times it doesnt, some full throttle runs it does it (I let off) and some it doesnt? Me and Brian thought it was bad gas, (ran it out) put new 93 octane, still does it. Motor has stock muffler and cat, all emmision stuff hooked up, stock exhaust manifolds, has the Hot Cam and 1.5 rockers for like .492 lift. Any ideas as to what is causing this, has a 160 thermostat and programmed for that. Also the motor has the 100 pound valve springs too. Pulled 1,3 plugs and they look good.
Help help
Old May 25, 2003 | 04:01 PM
yorkie's Avatar
pulled the egr valve vac line and drove it
No change, still pings, Basically it does it bad in 2nd gear at lower speed, with a load.
Old May 25, 2003 | 04:32 PM
yorkie's Avatar
just swapped lt4 module back to the stock one....
It made no difference, when it goes in to 2nd gear and then give it a load It pings like mad. go into 3rd and give it a load and it doesnt ping???????????
Old May 25, 2003 | 04:50 PM
Phatcaprice's Avatar
Did you give the oil pan a BFH mod?
Old May 25, 2003 | 04:54 PM
yorkie's Avatar
oh yeah I dented it good
It is detonation sound, not anything hitting the pan, spark knock.
Old May 25, 2003 | 06:06 PM
yorkie's Avatar
would plugs do this??
I am running Bosch Platinum's and they are new and the motor only has 500 miles on it.
Old May 25, 2003 | 07:00 PM
xxsaint69x's Avatar
may i ask what is the point of a 383 stroker with STOCK MANIFOLD/ALL EMISSIONS and a freakin hotcam ?
Old May 25, 2003 | 07:05 PM
yorkie's Avatar
well the other engine was toast, crank shot...
got the 3.75 crank for 130.00, "I" beam rods for 244.00 and speed pro pistons for 184.00 so I went this route.
Old May 25, 2003 | 08:02 PM
yorkie's Avatar
anyone??
Old May 25, 2003 | 08:06 PM
Rodrigues's Avatar
Try some race gas/ 100 octane or so. If this solves it you may want to retard your timing via PCM.
Old May 25, 2003 | 08:17 PM
yorkie's Avatar
I had pcmforless retard it 4 degrees and it...
still pings... Said tolulene or xylene, try that.
Old May 25, 2003 | 09:35 PM
Zerocool's Avatar
how much did it cost u to make your lt1 a stroker 383? total please
Old May 25, 2003 | 09:38 PM
yorkie's Avatar
well
161 crank, 184 pistons, 244 rods, 185 cam, about 500 in machine work, hundred in gaskets etc??
Old May 25, 2003 | 11:54 PM
yorkie's Avatar
Question anyone
Old May 26, 2003 | 12:17 AM
Xscream's Avatar
Have brian pull out some timing and see if that helps. Higher octaine will help with this as suggested but pulling out the timing is the cure for it - if that is the problem.
