Just checking before I yank it...
Old Dec 12, 2007 | 05:19 PM
OneEyedBadger's Avatar
That removing the AIR pump will not have negative affects. Car is in the sig (94 LT1). Emissions are NOT an issue, I don't want the car to get messed up over this.
Will there be a SES light? I searched and it sounded like no if I unplug the connector or something.
Just double checking
thanks
Old Dec 12, 2007 | 05:40 PM
PoorMan's Avatar
I took mine off along with my Cat. Removing it may cause premature Cat failure if you still have one.
Old Dec 12, 2007 | 05:42 PM
Since your car is OBD-I, you can disconnect the AIR pump, and not get a code/SES light, as long as there is a healthy fuse and relay in the circuit. Removing the AIR pump will not affect the way the engine runs, and will not hurt anything. It just runs for a couple minutes on start up to help heat the cats up faster. On the other hand, removing it will not increase performance in any way, other than the minimal affects of a 7# weight reduction.
Old Dec 12, 2007 | 05:45 PM
Yep, i know it's not going to make a noticeable difference.
I'm "Cleaning" out the engine bay while the car is down.
Sounds like I'm good to go, thanks guys!
Old Dec 12, 2007 | 06:34 PM
OK i just pulled it
There was a tube going air intake --> pump --> egr tubing
there was also a very small tube that went into something attached to the frame
what is that?
Old Dec 14, 2007 | 08:05 PM
the car misfires now.
I did alot of stuff (wire mod, swapped PCM's)
is there a write up to this so i can make sure I did it right
Old Dec 15, 2007 | 10:00 AM
<Puck>'s Avatar
The swapped PCM would be the most likely culprit. Can you run the original and see if it does the same thing?
Old Dec 15, 2007 | 11:30 AM
I made one thread to sum up everything. Simply no i cannot swap pcm's because the origninal pcm is bad
https://www.camaroz28.com/forums/sho...d.php?t=563633
Old Dec 15, 2007 | 03:25 PM
The AIR pump does not have anything at all to do with the "EGR tubing". It runs air from the AIR pump, through check valves, into the connections on the exhaust manifolds on both sides. That is not EGR. That is air added to the exhaust for the first couple minutes at startup, to help the cat heat up faster.
Did you cap the hole in the intake duct with a 5/8" vacuum cap?
Did you remove any of the tubing or the check valves running to the exhaust manifolds? If so, did you plug the connections to the exhaust manifolds?
The 94's do not have any "small tube" running into the frame that I am aware of. Where did the tube start? Where did it end? Was the tube possibly a small drain from the pump body (its been about 2 years since I removed mine)?
Old Dec 18, 2007 | 08:41 PM
Yes
No, a rubber hose goes from the air pump to a metal hose, splits in a "T", one going to each manifold. I just plugged it off before the T, right where the rubber hose would have connected from the air pump to metal lines
The tube was connected to the Air pump, it ran directly from the air pump to a little module (which is on a bracket bolted to the frame). The tube goes into this module, and then a electrical connector plugs into this module. I left the electrical connector plugged in. No soloution. Unplugged the connector, not the solution either
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
