Just bought z28. Problems
I just bought a 1994 z28 auto from the original owner. All stock older ladys car.
When I try to Accel it putters, revs up but doesn't go anywhere. Almost sounds like it's misfiring. Also, while I'n park. I would slightly rev and the oil gauge spikes up the. Down to 1/4 as the rpm decrease. Also does this at a stop light. Any ideas what this could be?
I just bought it last night and made a two hour drive home. I will be changing plugs, oil,oil filter. fuel filter tomorrow after work.
Re: Just bought z28. Problems
I have read the opti FAQ before I posted. Honestly,
The FAQ is all Greek to me. I don't have a ohm meter anymore and if I had one, I'm unsure How to check steps listed.
https://www.camaroz28.com/forums/sho...d.php?t=601565
Could be a number of things. Bad wire,plug,opti,coil, injectors could be gumming up also. Get it scanned with a good tool and see why its missing. Had the same problem and mine wad injectors.
There is no service/check engine light on. There is also a red water drop that comes on. It has new radiator,hoses, and coolant level and temps are fine. I live I'n s small town, who would have a OBD1 scanner? Would it pull a code without a CEL on the dash?
I will also try FI cleaner.
Has the car sat for long? We used a snap on scanner on mine which is 93. My check engine light would come on but would shut back off randomly. So many things it could be so I would start with the wires. I had too have a fuel injection clean forced through my injectors twice too get it running right could the gas have moisture In it?
It was a daily driver. It sat for about a week or two. The lady bought a 2011 2ss and thats why the car sat for a few weeks. She told me started it up every other day.
There is not a check engine light on. Just now, I started it up went to lunch it did not sputter or show any problem and turned it off when I parked When I started it back up
To pull onto the road it started sputtering again.
I will check ign system tomorrow. I changed the oil, oil filter, air filter, and fuel pump. Also cleaned the MAF today.
Took it out for a short drive. Zero hesitation and didn't very I'n rpm while at a stop.
Like I stated before, it will start to very I'n rpm after I restate the car ( I haven't had time to restart car and take it back out to see if problem is resolved.
I did notice the elbow to Tb was torn on the bottom.
I will order a aftermarket smooth elbow next Friday.
Thanks for all the input. I do try to run searches before I make a post.
I have much to learn and I will make a intro thread I'n the noon section with pictures, etc.
UPDATE: I have changed the oil, oil filter, spark plugs, cleaned the MAF,fuel filter, air filter and added gumout. I took the car out and the rough idle and puttering went away. It did putter/hesitate once when I hit 80-90% throttle.
There is a rip on the underside on the elbow that connects the the TB I have rigged something up until I can buy a new elbow.
So far I have been told to check/replace:
-Optispark
- air inlet line
-clean TB (unsure how to do so)
- coil wires
I will replace the wires, belt, elbow next weekend
Also, there were two plugs that were gummed up and wet looking. I don't remember which plugs they were. After reading many how tos to change plugs, it was not a hard task. I got the driver side all from under the car. And the passenger side from the top, all I removed was the alternator.
Any other ideas on what I should check. Or is there anyone local that has more knowledge to meet up and check my car out? I would pay for your gas money, buy you a beer, etc I'n return for the help.
-Optispark
- air inlet line
- coil wires
Do you think maybe its a problem with the AC compressor clutch and the belt is squealing?
