jumpy rpms at idle
Old Dec 9, 2006 | 02:23 PM
rsw3284's Avatar
jumpy rpms at idle
recently I had my pcm replaced. After i got it back from the dealer that re-flashed it my rpms are really jumpy at idle.. it'll jump between about 900 and 1300rpm, so from a cold start it tends to be really jerky when accelerating slowly. Also, when I drive around at say about 2k-2200 rpm, the needle won't drop back down when i press the clutch; it'll just stay at that same rpm until i'm going less than 10mph or so. It also smells like it's running pretty rich. Would this just be a re-programming error? -- or possibly a vacuum leak?
it's just odd that it happened after dealer flash.
edit: '97 Trans Am WS6 M6 - Underdrive Pulleys, 58mm TB, NGKTR55 plugs, Taylor 8mm otvc, Magnaflow cat-back, B&M short shifter
Old Dec 19, 2006 | 05:45 PM
rsw3284's Avatar
ttt
Old Dec 19, 2006 | 11:08 PM
mrmint69's Avatar
Sounds like the computer is relearning the engine and should adjust it self if there is nothing else done to it. This happens every time i disconnest the battery. Not as bad as you say but close.
Old Dec 20, 2006 | 10:10 AM
rsw3284's Avatar
That's what I thought too, but it was still doin it the next day .. after the computer had plenty of time to relearn.
Old Dec 20, 2006 | 11:15 AM
There is a "reset" procedure for the IAC system:
From Shoebox:
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Old Dec 20, 2006 | 06:24 PM
rsw3284's Avatar
I'll give that a try. thanks.
KYWes
Aug 4, 2015 01:54 PM
andrewcapps82
May 19, 2015 10:11 PM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
grgguy
17
Feb 23, 2015 07:57 PM
