Jumping tach?
Old Oct 18, 2003 | 12:51 PM
ZBLKHELLRZR's Avatar
Unhappy Jumping tach?
Just got rebuilt the engine and put it back together. My Accel 300+ ignition box died in the process. New taylor wires, and NGk's. 93Z w/ a 396. Cranks on 1st turn of the key and idles great but once you step on the gas the tach bounces from 2K to 3k or so. Engine isn't doing what the tack is or sounding like what the tach is doing as well. No back fires and no hesitation either. Any ideas before going the obvious route changing the opti? 65K on the original. Could the ignition box be the culprit? Got a new one coming and 2wks but I'd like to trace this problem before then. I;ll be double checking the wires just in cased I crossed em'.
Thanks for any input.
Old Oct 18, 2003 | 01:31 PM
madwolf's Avatar
Sometimes what you're describing can be due to a bad ground. Check and clean your PCM ground on the passenger side strut tower. If you're still running the aftermarket ignition and the ground cleaning didn't help, try bypassing the ignition.
Old Oct 19, 2003 | 05:23 AM
I'm not running through the box just straight to the coil. I'll try the other suggestion though. Thanks for the advice.
Old Oct 19, 2003 | 05:50 AM
M93Z's Avatar
My tach did the same thing when I disconnected the Accel 300 and ran through the coil. When I reconnected the ignition box the tach worked fine. Reading this makes me suspect the Accel coil has something to do with it.
PopoFormula
Oct 12, 2015 04:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
jerrysims71
Aug 15, 2015 12:47 PM
