jethot primary leak is too irritating
Old Nov 6, 2003 | 04:16 PM
got_hp?'s Avatar
i have the common leak on the slip-fit primary.
i tried insterting the tube with a healthy coating of RTV red to seal it up, but that didnt do squat.
i only had about 7 hours to let it cure (its my daily driver and that was the most time i had)
do you think if i let it cure overnight (12+ hours) it might work?
what other options are there?
i cant find a band clamp small enough for it.
im not going to do anything permanent like weld them up, or use that furnace cement stuff that someone else used.........i want to still be able to remove the headers if necessary.
Old Nov 6, 2003 | 05:24 PM
NVetro's Avatar
I thought the pressure from the exhaust is supposed to keep that slip fit primary on there. Are you sure one of your header bolts didn't back out?
Old Nov 6, 2003 | 05:54 PM
got_hp?'s Avatar
the header bolts are all tight Stage8 locking bolts..............the design is that the primary is supposed to be a tight enough fit that under heat/pressure it wont leak..............but for a lot of people it still does, which causes the O2 on the driver side to read lean, therefore making that side of cylinders richen up, losing performance.
not to mention, that damn ticking exhaust leak sound pisses me off!
94 CAMRO Z28's Avatar
Someone may be able to chime in but if I remember right, somebody was able to cure it with the cement sealer stuff that you use on fire places. Turns very hard and resists heat well..
Aaron
Old Nov 6, 2003 | 05:57 PM
LPE Z convt's Avatar
I used ultra copper high temp sealant and that worked fine for the slip joint...........
Old Nov 6, 2003 | 06:02 PM
got_hp?'s Avatar
how exactly did you apply it.......how long did you let it set?
Old Nov 6, 2003 | 06:13 PM
NVetro's Avatar
I belive with the high temp copper RTV you should let it sit for about 24 hours according to the package. I dont know if mine is leaking yet, I will check it out.
Old Nov 6, 2003 | 06:21 PM
got_hp?'s Avatar
if its leaking, you can usually hear it..........its a loud ticking sound at idle, and increases with rpm.
on mine, if you look at the header, there are dark stains around the slip-fit area, showing where the leak is.
Old Nov 6, 2003 | 07:18 PM
I applied it to the tube that pulls out about an inch up all the way around then slipped them together and let it sit for atleast 24hrs....
Old Nov 6, 2003 | 08:47 PM
got_hp?'s Avatar
thats gonna be the tough part, letting it sit 24hrs.......its the daily driver!
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
