Jet Hot LT install done
Old May 7, 2004 | 09:03 PM
Kris93/95Z28's Avatar
Well I might have set a record for LONGEST install time
I got the old headers out, new in, and all the work besides the bolting the LT headers up, and finishing the car (Altenator, Starter, O2s, etc...) done in 6 hours. Then the #2 primary bolts wouldn't go in, we decided that we needed to have the threads tapped....
After dropping it off, and the Mechanic Taking 6 1/2 weeks to TOUCH the car, it is finally done.
I took it to the muffler shop and they had to bend the Driver side header down since it was rubbing the floor board and they coulnd't bolt a collector to it
Then they had to cut the Transmission cross member, and it rubs just slightly when taking off, but after you get going it is all good.
All in all
The car pulls so much harder than with the Midlengths, some of that might be do to the Pace Setters having leaks, but LTs really woke up the car
Old May 7, 2004 | 09:22 PM
Spinner's Avatar
Re: Jet Hot LT install done
All in all
New motor mounts = no more rubby rub.
Old May 7, 2004 | 10:58 PM
Seal's Avatar
it took my buddy and i less than 3 hours
i was mostly watching, and he was just doing all the work tho
Old May 11, 2004 | 02:02 PM
Riddlerlt1's Avatar
Kris hey buddy whats going on? By the way i ment to ask you the other night, what header bolts did you end up going with? That is really the only thing i havent decided on yet.
Old May 11, 2004 | 02:05 PM
Red96Lt1's Avatar
I went with the stage 8's. It was nice to have 2 options to tighten the bolts down. And they will never back out. It took me 20 hours or so to do the install. I had to grind down the k member. It took me like 4 hours just to get the drivers side in.
Old Jun 14, 2004 | 01:52 PM
Shue97_Z28's Avatar
hey guys, im having a problem with my passenger side header. its bolted down and still sits right on top of the frame rail. i know if i start it up and rev the engine it will snap the bolts off in the head. any ideas on how to fix this??
Old Jun 14, 2004 | 02:22 PM
CamaroBoy96Z28's Avatar
Try a poly motor mount, seems yours are sagging A LOT. Mine are sagging a bit too but not enough for the header to touch the k-member. It took me 1 week to delete EGR and AIR, install my Jet Hots and do plugs and wires with minimal help in 85-90* July heat last summer in my dad's driveway. This was also with an emergency order from Thunder for more opti ends because it took me a set to figure out how to crimp them and its so easy too. Live and learn. Those headers are awesome by the way.
Nov 18, 2023 07:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
GigaMp3z
Feb 20, 2003 02:57 PM
