Jegs Starter
Old Dec 28, 2005 | 11:13 AM
  #16
Z28barnett's Avatar
Re: Jegs Starter
I tried the jegs stater that you are looking at.
It is a nice starter. It would not fit past my 1 3/4 SLP singel cat mids. I would have to remove the y-pipe to put it in.
The wide dual purpose 153 / 168 adjustable adapter would not allow the starter to go into place past the pipes and seemed like it was going to overlap the oil pan.
One thing people miss it the fact that the LT1 starter is a gear reduction unit. It used a planetary gear reduction rather than the spur gear reduction. So it looks like a long thin standard starter.
The LT1 is smaller and lighter than the Jegs starter.
I went to a local rebuilder and he swapped a new solenoid on my starter, not exactly factory but works good.
I would go with a rebuilt LT1 unless you are having major problems with heat soak or clearance.
Z28
Old Dec 28, 2005 | 11:17 AM
  #17
Zeueses 97 RamAir's Avatar
Re: Jegs Starter
lt1/lt4 starter is very good just get a good batterry and you will be fine, I have an optima, well 2 one in front and in right rear.....
Old Dec 28, 2005 | 03:30 PM
  #18
STEER_INTO_IT's Avatar
Re: Jegs Starter
I have the jegs starter on mine and it does its job day in and out. It clears the headers as long as you rotate it correctly. If you are putting it in with the engine in the car, I would recomend putting the block peice in first without the starter attached and doing a fitcheck, I had to grind a little off the mounting block like the others. Also I found it easier to manuver in the close quarters with the 2 peices seperated.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
