JEGS brand opti-spark warning
Old Aug 20, 2007 | 11:36 AM
Mtxz453's Avatar
I recently changed my opti with the jegs brand about a month ago. Car was misfiring running like crap etc. So i decided to change the plugs wires and the whole distributer. I ordered the jegs brand one. I went to put it in and the car wouldn't even turn over just popped and backfired out of the intake. As soon as i put the old one back in it started up again. I did this with 3 different Jegs opti's. Finally on the third one i brought it to a mechanic and he took it apart and the timing is totally different then the GM opti. I called Jegs and told them but they couldn't do anything but take the old one back.. i dont know what they are doing with their opti's but supposedly thats the only one they make for my car. I've noticed a lot of other guys are having this problem and are trying to fix other things besides the opti, so if you ordered a JEGS opti and are having this problem.. check the opti
Old Aug 20, 2007 | 11:52 AM
chevyinside's Avatar
I have one on my car from about 6 months ago . works fine . Had it apart saw nothing diffrent from to oem one . I had a 20 yaer gm master tech look at it and he couldnt see the diffrence either . You sure you didnt just clock it wrong on the camshaft ?
Old Aug 22, 2007 | 02:44 PM
Mtxz453's Avatar
positive.. like i said after i couldn't get the first few to work i brought it to my mechanic and he took it totally apart and showed me that the timing is totally different. Maybe it was a coincidence that they sent me 3 opti's with the wrong timing but i've called them numerous times and they said that they were sending me the right one for my model car. I have the msd cap and rotor on my old distributer and everything is fine now.
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
DETROIT_AREA_00_SS
Aug 14, 2002 08:00 PM
