Jack Stands - Where is Safe????
Old 04-08-2003, 03:42 PM
TToP's Avatar
Stupid question but when ever I use stands, or even a jack, I really don't trust myself or the damn car. Anyone know where to properly jack and place stands on the 4 gens? Pics would be awsome if anyone has any.
TToP is offline
Old 04-08-2003, 04:15 PM
LPEdave's Avatar
I don't have any pictures out there, but here's a write-up: http://www.go-fast.org/z28/maintenance.html#Jack
Dave
LPEdave is offline
Old 04-08-2003, 08:43 PM
97FormulaWS-6's Avatar
I don't have a writeup or pics... but I put mine on the back part of the front sub-frames... and for the rears, just infront of the LCA mtg points on one of the sub-frames there.
97FormulaWS-6 is offline
Old 04-08-2003, 09:10 PM
Originally posted by 2CNTRY
"Jack from under the differential case"
Is this a good thing to do? I read in a VW Volkswagen manual not to do this. Are our cases just stronger?
You're talking a VW there..... aluminum bellhousing... Vs our Steel rearends..... that's the only place I jack the rear of my car up from... it's the easiest... one jack lifts the entire rear.... whereas the fron I have to do with 2 jacks at the same time... one on each side...
Old 04-18-2003, 09:18 PM
grendal's Avatar
I could be wrong, but it doesn't seem good to jack from the differential housing on an f-body since it has a sway bar, you're really jacking on the sway bar..... seems like that might snap like a twig or bend.
I like jacking from the crossmember in the front, but then I puta jackstand on both sides at the front subframe, on or near the spot where the BMR subframe connectors weld onto the frame....
I personally wouldn't spend hours under a car except under ramps or multiple jack stands though.... Also be careful of BENDING the floor pan/subframe sections with jackstands. I suggest using some small scraps of wood as buffers. I've bent up my underside a little with cheap floor jacks and the pointy edges of jackstands.... they really aren't designed for soft unibody cars Wood scraps are your friend.
-Michael
grendal is offline
Old 04-18-2003, 10:08 PM
Dave88LX's Avatar
I jack under the pumpkin as well. It doesn't jack on the sway bar.
Front I jack on teh K-member.
I put jackstands under the sides in the provided notches.
http://paradox.shacknet.nu/dave88lx/...ch/garage2.jpg
Dave88LX is offline
Old 04-18-2003, 11:08 PM
Laymaster's Avatar
i place the jackstands in the front under the A-Arms or crossmember and in the rear on the rear subframes....
Laymaster is offline
football4life
10-04-2015 07:48 AM
4586
09-27-2015 01:55 PM
ryanhilsgen
9
09-21-2015 07:34 PM
raroz28
09-08-2015 06:10 AM
rideordie
09-07-2015 08:22 AM
Quick Reply: Jack Stands - Where is Safe????
