Jack Stands - Where is Safe????
Stupid question but when ever I use stands, or even a jack, I really don't trust myself or the damn car. Anyone know where to properly jack and place stands on the 4 gens? Pics would be awsome if anyone has any.
I don't have any pictures out there, but here's a write-up: http://www.go-fast.org/z28/maintenance.html#Jack
Dave
Dave
Originally posted by 2CNTRY
"Jack from under the differential case"
Is this a good thing to do? I read in a VW Volkswagen manual not to do this. Are our cases just stronger?
I could be wrong, but it doesn't seem good to jack from the differential housing on an f-body since it has a sway bar, you're really jacking on the sway bar..... seems like that might snap like a twig or bend.
I like jacking from the crossmember in the front, but then I puta jackstand on both sides at the front subframe, on or near the spot where the BMR subframe connectors weld onto the frame....
I personally wouldn't spend hours under a car except under ramps or multiple jack stands though.... Also be careful of BENDING the floor pan/subframe sections with jackstands. I suggest using some small scraps of wood as buffers. I've bent up my underside a little with cheap floor jacks and the pointy edges of jackstands.... they really aren't designed for soft unibody cars
Wood scraps are your friend.
-Michael
Wood scraps are your friend.-Michael
I jack under the pumpkin as well. It doesn't jack on the sway bar.
Front I jack on teh K-member.
I put jackstands under the sides in the provided notches.
http://paradox.shacknet.nu/dave88lx/...ch/garage2.jpg
