An Intermittent Stumble!
Old Jun 23, 2004 | 09:04 AM
LT1ponykilla's Avatar
What are somethings that would cause this? I just recently switched to long tubes and duals and never had these problems before. I also blocked off my EGR and AIR when I installed the long tubes. Could this have anything to do with it and is it possible I may need a good tune for the new exhaust and air/egr block offs?
Old Jun 23, 2004 | 02:23 PM
Anyone?
Old Jun 23, 2004 | 03:27 PM
southern78's Avatar
Did you turn off the EGR in the PCM?
Old Jun 23, 2004 | 03:39 PM
O-taka's Avatar
you could have burned a wire on one of the long tubes
even w/ heat shields, they can't touch at all. need air gap all around
Old Jun 23, 2004 | 03:40 PM
Im really not sure. Its been so long since I got the pcmforless tune I dont remember. If not, could that be the problem and what would it do?
Old Jun 23, 2004 | 03:42 PM
Wouldnt a wire be a constant miss though and not intermittant?
Old Jun 23, 2004 | 08:14 PM
O-taka's Avatar
i burned a wire once and it stumbled at lower rpm.
above 3,000 it got less, but yeah, dint go away entirely
Old Jun 23, 2004 | 11:12 PM
Mines kinda weird cause it doesnt happen all the time or everyday for that matter. I looked through the plug wires and didnt see anything but maybe I could tell more if I had it on a lift.
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
