Intermittent Starting Issues
Old May 31, 2012 | 12:43 PM
Camarokid95's Avatar
I have a 95 Camaro Z28, I installed Pacesetter Long tubes about 2 weeks ago, and had Madtuner tune my PCM. I deleted my egr and smog. Recently i've had some starting issues. Last summer I had the infamous issue of the car not starting until i let off the key (check valve in the fuel pump bad). I replaced the fuel pump with a brand new acdelco unit in April. I had 42 lbs of fuel pressure at the key and 36 at idle. Sometimes the car doesnt start until i left off the key again. Could it be the fuel pump again? Recently, when i start the car and drive it and then shut it off and try to refire it, the car will not start or start and then die. The car seems to be running fine once its started, no miss. So i'm thinking my issues are fuel or spark related, or both? Any ideas what would make the car die after starting or not start at all? My battery, alternator and starter are all good i had them checked out.
Old May 31, 2012 | 08:05 PM
my1994z28's Avatar
Re: Intermittent Starting Issues
I would check the FPR,)fuel pressure regulator)
Old Jun 1, 2012 | 12:54 PM
I'll check the regulator this weekend. Thanks!
97Z28Muscle
Feb 6, 2015 10:44 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
